2 Replies Latest reply on Feb 4, 2013 5:19 PM by Ross Hurley
    Link to InDesign
    Ross Hurley
      Hi all,
      Does InDesign link to Elements as it does to Photoshop? in other words, can you right-click a graphic in InDesign and directly open the original file in Elements as you can with Photoshop?
      Thanks.
        • 1. Re: Link to InDesign
          99jon Adobe Community Professional & MVP
          Hi Ross
          I’m not sure it’s possible as Adobe In Design has a CMYK workflow and PSE doesn’t support CMYK. Obviously you could use RGB images and graphics and edit them in PSE and convert in ID but I don’t think you will get the integration you need.
          You will possibly find more help on the ID forum.
          http://forums.adobe.com/community/indesign
          • 2. Re: Link to InDesign
            Ross Hurley Level 1
            Thanks for that Jon. Looking at Help for ID CS6 on the Internet however says that ID uses the OS to determine what application to open a placed graphic in. Hence, if I've got Elements as the default app for the graphics, then opening a graphic up directly from ID's Links panel should open them up in Elements. Help was pretty clear so I don't think I need to repost this question on that forum.
            Ross
