6 Replies Latest reply on Feb 4, 2013 6:47 AM by dasdeckone
    socket callback
    dasdeckone
      hi there.
      i want my scrip to react on messages from a socket.
      i tried something like this.
      Test.prototype.constructor = Test;
      function Test()
          this.socket = new Socket;
          this.socket.timeout = 10;
          var con = this.socket.open("127.0.0.1:9876","UTF-8");
      Test.prototype.test = function()
          var target = 'indesign-8.0';
          var m = new BridgeTalk();
          m.target = 'indesign-8.0';
              while(true)
              var res = this.socket.read();
              if(res.length > 0)
               m.send();
                  alert(res);
                  else
                  $.sleep(50);
          Model.init();
      var t = new Test();
      t.test();
      this kind of works. an "alert" is shwon every time i send a message from the other side.
      but the while loop will block everything else. is there a way to prevent this?
      i also had the idea to implement a threaded socket in a c++ library, but it seems i can non use callbacks from an external object?
      i can not see a way of calling a javascript function from my c++ library. i can only react on calls.
      please ask if i'm not clear as to what i'm trying to do.
      cheers
      jm
