1. Re: Change Tool pane to floating palettes (or even menus)?
George Johnson Feb 4, 2013 9:54 AM (in response to benwiggy)No, it's not possible. Acrobat 11 is abut more flexible with the ability to create tool sets that you can create and load at will, as well as a detachable Comments list.
2. Re: Change Tool pane to floating palettes (or even menus)?
benwiggy Feb 4, 2013 9:58 AM (in response to George Johnson)Thanks. I suspected as much. I've put it a feedback request for the revolutionary UI feature of "commands in menus". It might get phased in by 2020.
3. Re: Change Tool pane to floating palettes (or even menus)?
Gilad D (try67) Feb 4, 2013 10:00 AM (in response to benwiggy)Actually, it is possible, to some extent. One way of doing it is to use a script to create your own customized menu of the commands you most use.
This menu can be associated with a button located on the tool-bar so in effect you could access all of these tools without actually opening the Tools panel. I'm working on developing such a script, as a matter of fact, so if you're interested in it, contact me privately (by PM or at try6767[at]gmail.com).
