5 Replies Latest reply on Oct 22, 2017 1:16 AM by Otto Hänninen
    Run Script on Document Open Event
    jkinsman
      Ok so I know about the afterOpen event and I think I understand how to use it, however, I don't understand how to make it open for a specific document.
      I don't want this script to run on every document that I open, I want to embed it in a documnt and then run it everytime I open that document. Is this possible?
      Perhaps run the script from scripts label?
      Or would I just put a script in the startup panel and then create a session script that checks the name of each document opened and then runs the script if I have a match?
        • 1. Re: Run Script on Document Open Event
          dulajun Level 2
          As you chart put this in the startup scripts folder
          //startup script
          #targetengine "session"
          main();
          function main(){
              var myEventListener = app.eventListeners.add("afterOpen", excuteScriptLabel);
          function excuteScriptLabel(myEvent){
                    //The parent of the event is the document.
                    var myDocument = myEvent.parent;
              if (myDocument.constructor.name == "Document") {
                  if (myDocument.label != "")
                      app.doScript(myDocument.label, ScriptLanguage.javascript);
          Then try this line on a document and save it, then open the same file and some other others, you will notice that this code only excuted on that document:
          app.activeDocument.label = "alert (\"Yes\");";
          • 2. Re: Run Script on Document Open Event
            haim6130 Level 1
            You said that if I want to script to run of specific document, I need to put that line in the document.
            Where \ How do I put that code line in the document?
            And, The script that you first wrote, how do I run it? just save a JSX of it in the 'startup script' folder?
            • 3. Re: Run Script on Document Open Event
              Otto Hänninen
              Thank you dulajun for the example code. Trying to use it in Acrobat X (javascripts-folder) produces this error below; the line 2 contains statement :
              Why this error:
              Acrobat EScript Built-in Functions Version 10.0
              Acrobat SOAP 10.0
              SyntaxError: illegal character
              2:Folder-Level:App:AnydocOpenEvent.js
              • 4. Re: Run Script on Document Open Event
                Hi Otto,
                I hope, the "why" is clear to you.
                If not: This script is written in ExtendScript for InDesign.
                It's not a JavaScript script for Acrobat X.
                Regards,
                Uwe
                • 5. Re: Run Script on Document Open Event
                  Otto Hänninen Level 1
                  Thank you Uwe, yes, I suspected something like this, but as I am new to both javascripting and scripting for Acrobat, I did not recognize the difference in programming environments (towards this extent it would be nice to either users to note their environment in code comments, I only wish I remembered to do so, or to have language recognizer tool that would tell which environment(s) a given code would run).
                  Are you able to help me getting the afterOpen event processing work - at this point I'd need an example that would e.g. show a dialog when the event is handled "Hello world, I'm being opened now!".
                  Best regards
                  Otto
