1. Re: Not able to apply the Premiere Pro 6.0.2 update
Jeff A Wright Feb 4, 2013 2:25 PM (in response to DellPatrick)Branching this to a new discussion as the previous discussion was regarding Photoshop Lightroom 4.3 on Mac OS.
DellPatrick what process did you go through to uninstall the applications? Also which operating system are you using?
2. Re: Not able to apply the Premiere Pro 6.0.2 update
DellPatrick Feb 4, 2013 2:55 PM (in response to Jeff A Wright)Hi Jeff,
I uninstalled just now once again using the uninstaller found in the Applications / Premiere Pro CS6.app content directory and re-installed using a full version downloaded from the Download Assistant, not the Application Manager.
Still, i cannot apply the update manually citing the following error code:
U44M2I218
3. Re: Not able to apply the Premiere Pro 6.0.2 update
DellPatrick Feb 4, 2013 3:00 PM (in response to Jeff A Wright)02/04/13 12:38:17:167 | [INFO] | | OOBE | DE | | | | 6310 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 12:38:17:167 | [INFO] | | OOBE | DE | | | | 6310 | Visit http://www.adobe.com/go/loganalyzer/ for more information
02/04/13 12:38:17:167 | [INFO] | | OOBE | DE | | | | 6310 | START - Installer Session
02/04/13 12:38:17:167 | [INFO] | | OOBE | DE | | | | 6310 | RIBS version: 7.0.0.91
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | OSX version: 10.6.8
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Total Timer]
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | CHECK: Single instance running
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | CHECK : Credentials
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Load Deployment File
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | deploymentFile option not given
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | CHECK : Another Native OS installer already running
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Create Required Folders
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Assuming install mode
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Looking up install source path
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Sync Media DB ...
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Sync Media DB]
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Pre check media db sync
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | End of Pre check media db sync. Exit code: 0
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Sync Media DB] took 22 milliseconds (0.022 seconds)
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Ready to initialize session to start with ...
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [CreatePayloadSession]
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Updated source path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 12:38:17:173 | [INFO] | | OOBE | DE | | | | 6310 | Updating media info for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 12:38:17:174 | [INFO] | | OOBE | DE | | | | 6310 | Ignoring original data since install source is local
02/04/13 12:38:17:174 | [INFO] | | OOBE | DE | | | | 6310 | Type: 0, Volume Order: 1, Media Name: PremiereProTrial-6.0.2-mul-AdobeUpdate
02/04/13 12:38:17:174 | [INFO] | | OOBE | DE | | | | 6310 | Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 12:38:17:174 | [INFO] | | OOBE | DE | | | | 6310 | -------------------- END - Updating Media Sources - END --------------------
02/04/13 12:38:17:175 | [INFO] | | OOBE | DE | | | | 6310 | Supported RIBS version range: [0.0.0.0,7.0.0.91]
02/04/13 12:38:17:176 | [INFO] | | OOBE | DE | | | | 6310 | ----------------- CreatePayloadSession: machine is x86 ---------------
02/04/13 12:38:17:553 | [INFO] | | OOBE | DE | | | | 6310 | ______ Verify Dependency Subscribers ______
02/04/13 12:38:17:553 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 12:38:17:553 | [INFO] | | OOBE | DE | | | | 6310 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: 0 (0,0)
02/04/13 12:38:17:553 | [INFO] | | OOBE | DE | | | | 6310 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 12:38:17:554 | [INFO] | | OOBE | DE | | | | 6310 | Patch Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} can be applied to product Adobe Premiere Pro CS6 6.0.0.0 {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Setting property "installSourcePath" to: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Setting property "mode" to: silent
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Setting property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Setting property "workflow" to: updater
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Overwrite property "extensionsOnly" to: 1
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Overwrite property "mode" to: silent
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Overwrite property "patchesOnly" to: 1
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Overwrite property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 12:38:18:373 | [INFO] | | OOBE | DE | | | | 6310 | Overwrite property "workflow" to: updater
02/04/13 12:38:18:374 | [INFO] | | OOBE | DE | | | | 6310 | Found payload actions:
02/04/13 12:38:18:374 | [INFO] | | OOBE | DE | | | | 6310 | Deciding what installer mode to use...
02/04/13 12:38:18:393 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN Setting requested payload actions
02/04/13 12:38:18:394 | [INFO] | | OOBE | DE | | | | 6310 | Value returned on lookup of payload: Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is: false
02/04/13 12:38:18:394 | [INFO] | | OOBE | DE | | | | 6310 | Action string for Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is install
02/04/13 12:38:18:394 | [INFO] | | OOBE | DE | | | | 6310 | END Setting requested payload actions
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | Collected advanced path check information for INSTALLDIR
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR is a well-formed path
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR is not the root path
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR is on a local volume
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR is on a writable volume
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR is not on a case sensitive volume
02/04/13 12:38:18:396 | [INFO] | | OOBE | DE | | | | 6310 | INSTALLDIR passed path basic path validation: /Applications
02/04/13 12:38:18:433 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:18:444 | [INFO] | | OOBE | DE | | | | 6310 | In InstallPreSystemCheckProc
02/04/13 12:38:18:444 | [INFO] | | OOBE | DE | | | | 6310 | Custom action return code: 0
02/04/13 12:38:18:444 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 10 milliseconds (0.01 seconds)
02/04/13 12:38:18:541 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 12:38:18:541 | [INFO] | | OOBE | DE | | | | 6310 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 12:38:18:541 | [INFO] | | OOBE | DE | | | | 6310 | END InstallOperationsQueue Unordered operations
02/04/13 12:38:18:541 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 12:38:18:541 | [INFO] | | OOBE | DE | | | | 6310 | END InstallOperationsQueue Ordered operations
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | Payloads passed preflight validation.
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | Call PreSession Custom Hook
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | In InstallSessionOpenProc
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | Custom action return code: 0
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | END InstallOperationsQueue Unordered operations
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 12:38:18:582 | [INFO] | | OOBE | DE | | | | 6310 | END InstallOperationsQueue Ordered operations
02/04/13 12:38:18:696 | [INFO] | | OOBE | DE | | | | 6310 | Calling the custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 12:38:18:696 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:18:697 | [INFO] | | OOBE | DE | | | | 6310 | In PrePayloadInstallProc
02/04/13 12:38:18:697 | [INFO] | | OOBE | DE | | | | 6310 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 12:38:18:697 | [INFO] | | OOBE | DE | | | | 6310 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 12:38:18:707 | [INFO] | | OOBE | DE | | | | 6310 | CH: Get user id
02/04/13 12:38:18:708 | [INFO] | | OOBE | DE | | | | 6310 | uid = 503
02/04/13 12:38:18:708 | [INFO] | | OOBE | DE | | | | 6310 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 12:38:18:713 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 12:38:18:718 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 12:38:18:720 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 12:38:18:722 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 12:38:18:723 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 12:38:18:724 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 12:38:18:724 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 12:38:18:724 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 12:38:18:725 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 12:38:18:725 | [INFO] | | OOBE | DE | | | | 6310 | Custom action return code: 0
02/04/13 12:38:18:725 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 28 milliseconds (0.028 seconds) DTR = 891714 KBPS (870.815 MBPS)
02/04/13 12:38:18:725 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:18:726 | [INFO] | | OOBE | DE | | | | 6319 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 12:38:18:726 | [INFO] | | OOBE | DE | | | | 6319 | Installer Operation: PayloadUninstaller
02/04/13 12:38:18:727 | [INFO] | | OOBE | DE | | | | 6319 | Session {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} modify request for AdobeCode: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 12:38:18:750 | [INFO] | | OOBE | DE | | | | 6319 | Effective AdobeCode for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 12:38:18:791 | [INFO] | | OOBE | DE | | | | 6319 | PDB install manipulation failed
02/04/13 12:38:18:826 | [INFO] | | OOBE | DE | | | | 6310 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: -1 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 12:38:18:826 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 101 milliseconds (0.101 seconds)
02/04/13 12:38:18:828 | [INFO] | | OOBE | DE | | | | 6310 | User specified overrideFile:
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | The csu inventory was not updated for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}, value of local var is -1
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | In PrePayloadInstallProc
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 12:38:18:830 | [INFO] | | OOBE | DE | | | | 6310 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 12:38:18:833 | [INFO] | | OOBE | DE | | | | 6310 | CH: Get user id
02/04/13 12:38:18:833 | [INFO] | | OOBE | DE | | | | 6310 | uid = 503
02/04/13 12:38:18:833 | [INFO] | | OOBE | DE | | | | 6310 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 12:38:18:834 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 12:38:18:835 | [INFO] | | OOBE | DE | | | | 6310 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 12:38:18:836 | [INFO] | | OOBE | DE | | | | 6310 | Custom action return code: 0
02/04/13 12:38:18:836 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 5 milliseconds (0.005 seconds) DTR = 800 KBPS (0.78125 MBPS)
02/04/13 12:38:18:951 | [INFO] | | OOBE | DE | | | | 6310 | No operation. We're done:
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | Total components installed: 0
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | Total components repaired: 0
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | Total components removed: 0
02/04/13 12:38:20:953 | [WARN] | | OOBE | DE | | | | 6310 | DW050: The following payload errors were found during install:
02/04/13 12:38:20:953 | [WARN] | | OOBE | DE | | | | 6310 | DW050: - Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial: Install failed
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | Call PostSession Custom Hook
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | ::START TIMER:: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | In InstallSessionCloseProc
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | Custom action return code: 0
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 12:38:20:953 | [INFO] | | OOBE | DE | | | | 6310 | :: END TIMER :: [Total Timer] took 5289 milliseconds (5.289 seconds) DTR = 4620.16 KBPS (4.51187 MBPS)
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | -------------------------------------- Summary --------------------------------------
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | - 0 fatal error(s), 0 error(s)
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | OSX version: 10.6.8
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | -------------------------------------------------------------------------------------
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | Exit Code: 7 - Unable to complete Silent workflow.
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 12:38:21:954 | [INFO] | | OOBE | DE | | | | 6310 | END - Installer Session
02/04/13 13:41:30:729 | [INFO] | | OOBE | DE | | | | 30071 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 13:41:30:729 | [INFO] | | OOBE | DE | | | | 30071 | Visit http://www.adobe.com/go/loganalyzer/ for more information
02/04/13 13:41:30:729 | [INFO] | | OOBE | DE | | | | 30071 | START - Installer Session
02/04/13 13:41:30:729 | [INFO] | | OOBE | DE | | | | 30071 | RIBS version: 7.0.0.91
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | OSX version: 10.6.8
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Total Timer]
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | CHECK: Single instance running
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | CHECK : Credentials
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Load Deployment File
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | deploymentFile option not given
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | CHECK : Another Native OS installer already running
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Create Required Folders
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Assuming install mode
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Looking up install source path
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Sync Media DB ...
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Sync Media DB]
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Pre check media db sync
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | End of Pre check media db sync. Exit code: 0
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Sync Media DB] took 20 milliseconds (0.02 seconds)
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Ready to initialize session to start with ...
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [CreatePayloadSession]
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/04/13 13:41:30:735 | [INFO] | | OOBE | DE | | | | 30071 | Updated source path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 13:41:30:736 | [INFO] | | OOBE | DE | | | | 30071 | Updating media info for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 13:41:30:736 | [INFO] | | OOBE | DE | | | | 30071 | Ignoring original data since install source is local
02/04/13 13:41:30:736 | [INFO] | | OOBE | DE | | | | 30071 | Type: 0, Volume Order: 1, Media Name: PremiereProTrial-6.0.2-mul-AdobeUpdate
02/04/13 13:41:30:736 | [INFO] | | OOBE | DE | | | | 30071 | Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 13:41:30:736 | [INFO] | | OOBE | DE | | | | 30071 | -------------------- END - Updating Media Sources - END --------------------
02/04/13 13:41:30:738 | [INFO] | | OOBE | DE | | | | 30071 | Supported RIBS version range: [0.0.0.0,7.0.0.91]
02/04/13 13:41:30:738 | [INFO] | | OOBE | DE | | | | 30071 | ----------------- CreatePayloadSession: machine is x86 ---------------
02/04/13 13:41:31:130 | [INFO] | | OOBE | DE | | | | 30071 | ______ Verify Dependency Subscribers ______
02/04/13 13:41:31:130 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 13:41:31:130 | [INFO] | | OOBE | DE | | | | 30071 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: 0 (0,0)
02/04/13 13:41:31:130 | [INFO] | | OOBE | DE | | | | 30071 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 13:41:31:131 | [INFO] | | OOBE | DE | | | | 30071 | Patch Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} can be applied to product Adobe Premiere Pro CS6 6.0.0.0 {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Setting property "installSourcePath" to: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Setting property "mode" to: silent
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Setting property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Setting property "workflow" to: updater
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Overwrite property "extensionsOnly" to: 1
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Overwrite property "mode" to: silent
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Overwrite property "patchesOnly" to: 1
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Overwrite property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 13:41:31:395 | [INFO] | | OOBE | DE | | | | 30071 | Overwrite property "workflow" to: updater
02/04/13 13:41:31:396 | [INFO] | | OOBE | DE | | | | 30071 | Found payload actions:
02/04/13 13:41:31:396 | [INFO] | | OOBE | DE | | | | 30071 | Deciding what installer mode to use...
02/04/13 13:41:31:416 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN Setting requested payload actions
02/04/13 13:41:31:417 | [INFO] | | OOBE | DE | | | | 30071 | Value returned on lookup of payload: Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is: false
02/04/13 13:41:31:417 | [INFO] | | OOBE | DE | | | | 30071 | Action string for Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is install
02/04/13 13:41:31:417 | [INFO] | | OOBE | DE | | | | 30071 | END Setting requested payload actions
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | Collected advanced path check information for INSTALLDIR
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR is a well-formed path
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR is not the root path
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR is on a local volume
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR is on a writable volume
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR is not on a case sensitive volume
02/04/13 13:41:31:419 | [INFO] | | OOBE | DE | | | | 30071 | INSTALLDIR passed path basic path validation: /Applications
02/04/13 13:42:03:407 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:03:412 | [INFO] | | OOBE | DE | | | | 30071 | In InstallPreSystemCheckProc
02/04/13 13:42:03:412 | [INFO] | | OOBE | DE | | | | 30071 | Custom action return code: 0
02/04/13 13:42:03:413 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 5 milliseconds (0.005 seconds)
02/04/13 13:42:03:520 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 13:42:03:520 | [INFO] | | OOBE | DE | | | | 30071 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 13:42:03:520 | [INFO] | | OOBE | DE | | | | 30071 | END InstallOperationsQueue Unordered operations
02/04/13 13:42:03:521 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 13:42:03:521 | [INFO] | | OOBE | DE | | | | 30071 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 13:42:03:521 | [INFO] | | OOBE | DE | | | | 30071 | END InstallOperationsQueue Ordered operations
02/04/13 13:42:03:565 | [INFO] | | OOBE | DE | | | | 30071 | Payloads passed preflight validation.
02/04/13 13:42:03:565 | [INFO] | | OOBE | DE | | | | 30071 | Call PreSession Custom Hook
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | In InstallSessionOpenProc
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | Custom action return code: 0
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | END InstallOperationsQueue Unordered operations
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 13:42:03:566 | [INFO] | | OOBE | DE | | | | 30071 | END InstallOperationsQueue Ordered operations
02/04/13 13:42:03:666 | [INFO] | | OOBE | DE | | | | 30071 | Calling the custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 13:42:03:666 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:03:666 | [INFO] | | OOBE | DE | | | | 30071 | In PrePayloadInstallProc
02/04/13 13:42:03:666 | [INFO] | | OOBE | DE | | | | 30071 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 13:42:03:666 | [INFO] | | OOBE | DE | | | | 30071 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 13:42:03:679 | [INFO] | | OOBE | DE | | | | 30071 | CH: Get user id
02/04/13 13:42:03:679 | [INFO] | | OOBE | DE | | | | 30071 | uid = 503
02/04/13 13:42:03:679 | [INFO] | | OOBE | DE | | | | 30071 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 13:42:03:684 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 13:42:03:685 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 13:42:03:686 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 13:42:03:686 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 13:42:03:686 | [INFO] | | OOBE | DE | | | | 30071 | Custom action return code: 0
02/04/13 13:42:03:686 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 20 milliseconds (0.02 seconds) DTR = 200 KBPS (0.195312 MBPS)
02/04/13 13:42:03:686 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:03:688 | [INFO] | | OOBE | DE | | | | 30214 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 13:42:03:688 | [INFO] | | OOBE | DE | | | | 30214 | Installer Operation: PayloadUninstaller
02/04/13 13:42:03:688 | [INFO] | | OOBE | DE | | | | 30214 | Session {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} modify request for AdobeCode: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 13:42:03:711 | [INFO] | | OOBE | DE | | | | 30214 | Effective AdobeCode for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 13:42:03:753 | [INFO] | | OOBE | DE | | | | 30214 | PDB install manipulation failed
02/04/13 13:42:03:788 | [INFO] | | OOBE | DE | | | | 30071 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: -1 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 13:42:03:788 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 101 milliseconds (0.101 seconds)
02/04/13 13:42:03:789 | [INFO] | | OOBE | DE | | | | 30071 | User specified overrideFile:
02/04/13 13:42:03:791 | [INFO] | | OOBE | DE | | | | 30071 | The csu inventory was not updated for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}, value of local var is -1
02/04/13 13:42:03:791 | [INFO] | | OOBE | DE | | | | 30071 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 13:42:03:791 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:03:791 | [INFO] | | OOBE | DE | | | | 30071 | In PrePayloadInstallProc
02/04/13 13:42:03:791 | [INFO] | | OOBE | DE | | | | 30071 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 13:42:03:792 | [INFO] | | OOBE | DE | | | | 30071 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 13:42:03:794 | [INFO] | | OOBE | DE | | | | 30071 | CH: Get user id
02/04/13 13:42:03:794 | [INFO] | | OOBE | DE | | | | 30071 | uid = 503
02/04/13 13:42:03:794 | [INFO] | | OOBE | DE | | | | 30071 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 13:42:03:796 | [INFO] | | OOBE | DE | | | | 30071 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 13:42:03:797 | [INFO] | | OOBE | DE | | | | 30071 | Custom action return code: 0
02/04/13 13:42:03:797 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 5 milliseconds (0.005 seconds) DTR = 800 KBPS (0.78125 MBPS)
02/04/13 13:42:03:872 | [INFO] | | OOBE | DE | | | | 30071 | No operation. We're done:
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | Total components installed: 0
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | Total components repaired: 0
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | Total components removed: 0
02/04/13 13:42:05:874 | [WARN] | | OOBE | DE | | | | 30071 | DW050: The following payload errors were found during install:
02/04/13 13:42:05:874 | [WARN] | | OOBE | DE | | | | 30071 | DW050: - Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial: Install failed
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | Call PostSession Custom Hook
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | ::START TIMER:: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 13:42:05:874 | [INFO] | | OOBE | DE | | | | 30071 | In InstallSessionCloseProc
02/04/13 13:42:05:875 | [INFO] | | OOBE | DE | | | | 30071 | Custom action return code: 0
02/04/13 13:42:05:875 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 13:42:05:875 | [INFO] | | OOBE | DE | | | | 30071 | :: END TIMER :: [Total Timer] took 36595 milliseconds (36.595 seconds) DTR = 0.437218 KBPS (0.000426971 MBPS)
02/04/13 13:42:06:875 | [INFO] | | OOBE | DE | | | | 30071 | -------------------------------------- Summary --------------------------------------
02/04/13 13:42:06:875 | [INFO] | | OOBE | DE | | | | 30071 | - 0 fatal error(s), 0 error(s)
02/04/13 13:42:06:875 | [INFO] | | OOBE | DE | | | | 30071 | OSX version: 10.6.8
02/04/13 13:42:06:875 | [INFO] | | OOBE | DE | | | | 30071 | -------------------------------------------------------------------------------------
02/04/13 13:42:06:875 | [INFO] | | OOBE | DE | | | | 30071 | Exit Code: 7 - Unable to complete Silent workflow.
02/04/13 13:42:06:876 | [INFO] | | OOBE | DE | | | | 30071 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 13:42:06:876 | [INFO] | | OOBE | DE | | | | 30071 | END - Installer Session
02/04/13 14:55:03:548 | [INFO] | | OOBE | DE | | | | 46426 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 14:55:03:548 | [INFO] | | OOBE | DE | | | | 46426 | Visit http://www.adobe.com/go/loganalyzer/ for more information
02/04/13 14:55:03:548 | [INFO] | | OOBE | DE | | | | 46426 | START - Installer Session
02/04/13 14:55:03:548 | [INFO] | | OOBE | DE | | | | 46426 | RIBS version: 7.0.0.91
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | OSX version: 10.6.8
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Total Timer]
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | CHECK: Single instance running
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | CHECK : Credentials
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Load Deployment File
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | deploymentFile option not given
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | CHECK : Another Native OS installer already running
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Create Required Folders
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Assuming install mode
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Looking up install source path
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Sync Media DB ...
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Sync Media DB]
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Pre check media db sync
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | End of Pre check media db sync. Exit code: 0
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Sync Media DB] took 19 milliseconds (0.019 seconds) DTR = 8210.53 KBPS (8.01809 MBPS)
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Ready to initialize session to start with ...
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [CreatePayloadSession]
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Updated source path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 14:55:03:554 | [INFO] | | OOBE | DE | | | | 46426 | Updating media info for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 14:55:03:555 | [INFO] | | OOBE | DE | | | | 46426 | Ignoring original data since install source is local
02/04/13 14:55:03:555 | [INFO] | | OOBE | DE | | | | 46426 | Type: 0, Volume Order: 1, Media Name: PremiereProTrial-6.0.2-mul-AdobeUpdate
02/04/13 14:55:03:555 | [INFO] | | OOBE | DE | | | | 46426 | Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 14:55:03:555 | [INFO] | | OOBE | DE | | | | 46426 | -------------------- END - Updating Media Sources - END --------------------
02/04/13 14:55:03:556 | [INFO] | | OOBE | DE | | | | 46426 | Supported RIBS version range: [0.0.0.0,7.0.0.91]
02/04/13 14:55:03:557 | [INFO] | | OOBE | DE | | | | 46426 | ----------------- CreatePayloadSession: machine is x86 ---------------
02/04/13 14:55:03:948 | [INFO] | | OOBE | DE | | | | 46426 | ______ Verify Dependency Subscribers ______
02/04/13 14:55:03:948 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 14:55:03:948 | [INFO] | | OOBE | DE | | | | 46426 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: 0 (0,0)
02/04/13 14:55:03:948 | [INFO] | | OOBE | DE | | | | 46426 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/04/13 14:55:03:949 | [INFO] | | OOBE | DE | | | | 46426 | Patch Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} can be applied to product Adobe Premiere Pro CS6 6.0.0.0 {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Setting property "installSourcePath" to: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Setting property "mode" to: silent
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Setting property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Setting property "workflow" to: updater
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Overwrite property "extensionsOnly" to: 1
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Overwrite property "mode" to: silent
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Overwrite property "patchesOnly" to: 1
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Overwrite property "updateManifestPath" to: /Users/Admin/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobePremiereProCS6-6.0.0-Trial/6.0.2/6.0.2.xml
02/04/13 14:55:04:096 | [INFO] | | OOBE | DE | | | | 46426 | Overwrite property "workflow" to: updater
02/04/13 14:55:04:097 | [INFO] | | OOBE | DE | | | | 46426 | Found payload actions:
02/04/13 14:55:04:097 | [INFO] | | OOBE | DE | | | | 46426 | Deciding what installer mode to use...
02/04/13 14:55:04:116 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN Setting requested payload actions
02/04/13 14:55:04:116 | [INFO] | | OOBE | DE | | | | 46426 | Value returned on lookup of payload: Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is: false
02/04/13 14:55:04:116 | [INFO] | | OOBE | DE | | | | 46426 | Action string for Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is install
02/04/13 14:55:04:117 | [INFO] | | OOBE | DE | | | | 46426 | END Setting requested payload actions
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | Collected advanced path check information for INSTALLDIR
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR is a well-formed path
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR is not the root path
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR is on a local volume
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR is on a writable volume
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR is not on a case sensitive volume
02/04/13 14:55:04:118 | [INFO] | | OOBE | DE | | | | 46426 | INSTALLDIR passed path basic path validation: /Applications
02/04/13 14:55:20:210 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:20:216 | [INFO] | | OOBE | DE | | | | 46426 | In InstallPreSystemCheckProc
02/04/13 14:55:20:217 | [INFO] | | OOBE | DE | | | | 46426 | Custom action return code: 0
02/04/13 14:55:20:217 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [System check :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 6 milliseconds (0.006 seconds)
02/04/13 14:55:20:326 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 14:55:20:326 | [INFO] | | OOBE | DE | | | | 46426 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 14:55:20:326 | [INFO] | | OOBE | DE | | | | 46426 | END InstallOperationsQueue Unordered operations
02/04/13 14:55:20:326 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 14:55:20:326 | [INFO] | | OOBE | DE | | | | 46426 | END InstallOperationsQueue Ordered operations
02/04/13 14:55:20:367 | [INFO] | | OOBE | DE | | | | 46426 | Payloads passed preflight validation.
02/04/13 14:55:20:367 | [INFO] | | OOBE | DE | | | | 46426 | Call PreSession Custom Hook
02/04/13 14:55:20:367 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | In InstallSessionOpenProc
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | Custom action return code: 0
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Pre session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN InstallOperationsQueue Unordered operations
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}: with operation install
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | END InstallOperationsQueue Unordered operations
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | BEGIN InstallOperationsQueue Ordered operations
02/04/13 14:55:20:368 | [INFO] | | OOBE | DE | | | | 46426 | END InstallOperationsQueue Ordered operations
02/04/13 14:55:20:476 | [INFO] | | OOBE | DE | | | | 46426 | Calling the custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 14:55:20:476 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:20:477 | [INFO] | | OOBE | DE | | | | 46426 | In PrePayloadInstallProc
02/04/13 14:55:20:477 | [INFO] | | OOBE | DE | | | | 46426 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 14:55:20:477 | [INFO] | | OOBE | DE | | | | 46426 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 14:55:20:488 | [INFO] | | OOBE | DE | | | | 46426 | CH: Get user id
02/04/13 14:55:20:488 | [INFO] | | OOBE | DE | | | | 46426 | uid = 503
02/04/13 14:55:20:489 | [INFO] | | OOBE | DE | | | | 46426 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 14:55:20:494 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 14:55:20:498 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 14:55:20:499 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 14:55:20:501 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 14:55:20:502 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | Custom action return code: 0
02/04/13 14:55:20:503 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 26 milliseconds (0.026 seconds) DTR = 960308 KBPS (937.8 MBPS)
02/04/13 14:55:20:504 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:20:505 | [INFO] | | OOBE | DE | | | | 46530 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 14:55:20:505 | [INFO] | | OOBE | DE | | | | 46530 | Installer Operation: PayloadUninstaller
02/04/13 14:55:20:505 | [INFO] | | OOBE | DE | | | | 46530 | Session {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} modify request for AdobeCode: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 14:55:20:529 | [INFO] | | OOBE | DE | | | | 46530 | Effective AdobeCode for: {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0} is {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 14:55:20:570 | [INFO] | | OOBE | DE | | | | 46530 | PDB install manipulation failed
02/04/13 14:55:20:605 | [INFO] | | OOBE | DE | | | | 46426 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: -1 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 14:55:20:605 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Payload Operation :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 101 milliseconds (0.101 seconds)
02/04/13 14:55:20:606 | [INFO] | | OOBE | DE | | | | 46426 | User specified overrideFile:
02/04/13 14:55:20:608 | [INFO] | | OOBE | DE | | | | 46426 | The csu inventory was not updated for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}, value of local var is -1
02/04/13 14:55:20:608 | [INFO] | | OOBE | DE | | | | 46426 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial 6.0.2.0 {1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}
02/04/13 14:55:20:609 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:20:609 | [INFO] | | OOBE | DE | | | | 46426 | In PrePayloadInstallProc
02/04/13 14:55:20:609 | [INFO] | | OOBE | DE | | | | 46426 | CH: MediaPath: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/AdobePremierePro6.0AllTrial-220812043536.dmg
02/04/13 14:55:20:609 | [INFO] | | OOBE | DE | | | | 46426 | CH: Helper Path: /Users/Admin/Library/Caches/Adobe/AAMUpdater/AdobePremiereProCS6-6.0.0-Trial/6.0.2/payloa ds/AdobePremierePro6.0AllTrial-220812043536/customactionHelper
02/04/13 14:55:20:611 | [INFO] | | OOBE | DE | | | | 46426 | CH: Get user id
02/04/13 14:55:20:612 | [INFO] | | OOBE | DE | | | | 46426 | uid = 503
02/04/13 14:55:20:612 | [INFO] | | OOBE | DE | | | | 46426 | CH: Processing for AC = {42CED1DA-1C36-45D2-88C0-C32DB6B82B49}
02/04/13 14:55:20:613 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app
02/04/13 14:55:20:613 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterRED.bundle
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/AAF.bundle
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/ImporterARRIRAW.bundle
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/CodeResources
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/_CodeSignature/CodeResources
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/CodeResources
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | CH: action = rm, path = /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framewo rk/_CodeSignature/CodeResources
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | Custom action return code: 0
02/04/13 14:55:20:614 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Pre payload :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 5 milliseconds (0.005 seconds) DTR = 800 KBPS (0.78125 MBPS)
02/04/13 14:55:20:697 | [INFO] | | OOBE | DE | | | | 46426 | No operation. We're done:
02/04/13 14:55:22:698 | [INFO] | | OOBE | DE | | | | 46426 | Total components installed: 0
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | Total components repaired: 0
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | Total components removed: 0
02/04/13 14:55:22:699 | [WARN] | | OOBE | DE | | | | 46426 | DW050: The following payload errors were found during install:
02/04/13 14:55:22:699 | [WARN] | | OOBE | DE | | | | 46426 | DW050: - Adobe Premiere Pro CS6_6.0.2_AdobePremierePro6.0AllTrial: Install failed
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | Call PostSession Custom Hook
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | ::START TIMER:: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}]
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | In InstallSessionCloseProc
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | Custom action return code: 0
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Post session :{1FB3B80F-CA2D-4DE3-A8AC-B20F977A04B0}] took 0 milliseconds (0 seconds)
02/04/13 14:55:22:699 | [INFO] | | OOBE | DE | | | | 46426 | :: END TIMER :: [Total Timer] took 19350 milliseconds (19.35 seconds) DTR = 1283.93 KBPS (1.25384 MBPS)
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | -------------------------------------- Summary --------------------------------------
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | - 0 fatal error(s), 0 error(s)
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | OSX version: 10.6.8
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | -------------------------------------------------------------------------------------
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | Exit Code: 7 - Unable to complete Silent workflow.
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/04/13 14:55:23:700 | [INFO] | | OOBE | DE | | | | 46426 | END - Installer Session
4. Re: Not able to apply the Premiere Pro 6.0.2 update
Jeff A Wright Feb 4, 2013 3:04 PM (in response to DellPatrick)Do you have an installation log located in Library/Logs/Adobe? You can find complete details on how to locate and interpret your installation logs at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
Also you may want to utilize the uninstaller located in Applications/Utilities/Adobe Installers instead. There has been various reports that the uninstall process invoked from this location leads to more successful results.
5. Re: Not able to apply the Premiere Pro 6.0.2 update
DellPatrick Feb 4, 2013 3:08 PM (in response to Jeff A Wright)Adobe software usually works great. It seems to me its biggest flaw is its installation management. Why are there two uninstallers? Why is this so confusing? Why can it not auto-detect errors? Why is there simple installation repair program? Why is there Creative Cloud and a "Regular" application download when they are identical.
This is a very, very frustrating thing.
