I am trying to convert a Flash Builder 4.5 project to Flash Builder 4.7. I am having a lot of problems and eventually gave up and deleted the project files and just re-made the projects from scratch.
However, I am having problems embedding an asset. This line works:
[Embed(source = "image.png", mimeType="image/png")]
This line:
[Embed(source = image.png", mimeType="image/png", compression="true")]
Genererates the following errors:
Description | Resource | Path | Location | Type |
Internal error in ABC generator subsystem, when generating code for: <removed>.as: java.lang.NullPointerException
at com.adobe.flash.compiler.internal.embedding.transcoders.JPEGTranscoder.equals(JPEGTranscoder.java:220) | |||||
at com.adobe.flash.compiler.internal.embedding.EmbedData.equals(EmbedData.java:522) | |||||
at java.util.WeakHashMap.eq(Unknown Source) | |||||
at java.util.WeakHashMap.get(Unknown Source) | |||||
at com.adobe.flash.compiler.internal.workspaces.Workspace.getCanonicalEmbedData(Workspace.java:933) | |||||
at com.adobe.flash.compiler.internal.units.EmbedCompilationUnitFactory.getEmbedData(EmbedCompilationUnitFactory.java:120) | |||||
at com.adobe.flash.compiler.internal.units.EmbedCompilationUnitFactory.getCompilationUnit(EmbedCompilationUnitFactory.java:62) | |||||
at com.adobe.flash.compiler.internal.tree.as.EmbedNode.resolveCompilationUnit(EmbedNode.java:116) | |||||
at com.adobe.flash.compiler.internal.tree.as.EmbedNode.resolveCompilationUnit(EmbedNode.java:126) | |||||
at com.adobe.flash.compiler.internal.tree.as.EmbedNode.resolveCompilationUnit(EmbedNode.java:43) | |||||
at com.adobe.flash.compiler.internal.units.EmbedCompilationUnitFactory.collectEmbedDatas(EmbedCompilationUnitFactory.java:136) | |||||
at com.adobe.flash.compiler.internal.as.codegen.ABCGenerator.generate(ABCGenerator.java:184) | |||||
at com.adobe.flash.compiler.internal.units.ASCompilationUnit.handleABCBytesRequest(ASCompilationUnit.java:374) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase.processABCBytesRequest(CompilationUnitBase.java:870) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase.access$300(CompilationUnitBase.java:107) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase$4$1.call(CompilationUnitBase.java:309) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase$4$1.call(CompilationUnitBase.java:305) | |||||
at com.adobe.flash.compiler.internal.units.requests.RequestMaker$1.call(RequestMaker.java:228) | |||||
at com.adobe.flash.compiler.internal.units.requests.RequestMaker$1.call(RequestMaker.java:222) | |||||
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) | |||||
at java.util.concurrent.FutureTask.run(Unknown Source) | |||||
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) | |||||
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) | |||||
at java.lang.Thread.run(Unknown Source) | <removed>.as | /<removed> | line 0 | Flex Problem |
and
Internal error in outgoing dependency subsystem, when generating code for:<removed>.as: java.lang.NullPointerException
at com.adobe.flash.compiler.internal.units.CompilationUnitBase.updateEmbedCompilationUnitDependencies(CompilationUnitBase.java:946) | |||||
at com.adobe.flash.compiler.internal.units.ASCompilationUnit.handleOutgoingDependenciesRequest(ASCompilationUnit.java:458) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase.processOutgoingDependenciesRequest(CompilationUnitBase.java:886) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase.access$500(CompilationUnitBase.java:107) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase$6$1.call(CompilationUnitBase.java:378) | |||||
at com.adobe.flash.compiler.internal.units.CompilationUnitBase$6$1.call(CompilationUnitBase.java:374) | |||||
Further, this line:
[Embed(source = "../../../../../../image.png", mimeType="image/png", compression="true", quality="70")]
Generates the following errors:
Internal error in outgoing dependency subsystem, when generating code for: image.png: java.lang.ArrayIndexOutOfBoundsException: 0
at com.adobe.flash.compiler.internal.units.EmbedCompilationUnit.analyze(EmbedCompilationUnit.java:224) | |||||
at com.adobe.flash.compiler.internal.units.EmbedCompilationUnit.handleOutgoingDependenciesRequest(EmbedCompilationUnit.java:193) | |||||
at java.lang.Thread.run(Unknown Source) | image.png | /<removed> | line 0 | Flex Problem |
The definition of base class Bitmap was not found. | <removed> | line 0 | Flex Problem |
and a warning:
Definition flash.utils.Bitmap could not be found. | <removed> | line 0 | Flex Problem |
I am trying to make the project of type "ActionScript Library Project" using the Flex 4.6 SDK overlayed with AIR SDK 3.5 however without including the AIR library files.
Here is some more clear info:
Steps to reproduce:
1. Use the Embed tag above a class variable to embed a png
[Embed(source = "Image.png", mimeType = "image/png", compression="true")]
private static var _imageClass:Class;
NOTE: This occurs with or without specifying the mimeType as long as compression is being set to "true"
2. Save/Compile the Code
3. Note the compiler errors:
Internal error in ABC generator subsystem, when generating code for: C:\Users\user\Adobe Flash Builder 4.7\TestProject\src\TestProject.as: java.lang.NullPointerException
at java.lang.Thread.run(Unknown Source) TestProject.as /TestProject/src line 0 Flex Problem
Internal error in outgoing dependency subsystem, when generating code for: C:\Users\user\Adobe Flash Builder 4.7\TestProject\src\TestProject.as: java.lang.NullPointerException
Actual Results:
Setting compression to true generates a compiler error.
Expected Results:
I expected to be able to compress embedded images with Flash Builder.
Workaround (if any):
None.
Additonal Notes:
Trying to explicitly set compression to false:
[Embed(source = "Image.png", mimeType = "image/png", compression="false")]
Generates the following error:
The attribute compression can't be used with the mime type: image/png
Switching the mimeType to jpeg in this case:
[Embed(source = "Image.png", mimeType = "image/jpeg", compression="false")]
The attribute compression can't be used with the mime type: image/jpeg
Anyone else get these results when trying to compress an embedded image?
Also, just note that specifying a quality:
[Embed(source = "Image.png", mimeType = "image/png", compression="true", quality="90")]
Changes the errors to:
Internal error in outgoing dependency subsystem, when generating code for: C:\Users\clivsey\Adobe Flash Builder 4.7\TestProject\src\Image.png: java.lang.ArrayIndexOutOfBoundsException: 0
at java.lang.Thread.run(Unknown Source) Image.png /TestProject/src line 0 Flex Problem
and a warning:
Here's the ENTIRE code that gets this error:
package
import flash.display.Sprite;
public class TestProject extends Sprite
[Embed(source = "Image.png", mimeType = "image/jpeg", compression="true", quality="80")]
public function TestProject()
