11 Replies Latest reply on Feb 7, 2013 12:58 AM by BEGINNER_X
    Script Label
    BEGINNER_X Level 3
      Hi All,
      For my requirement i want to get a list of all page items with "id" value  in script label.
      Script Label concept in entirely new for me.
      Below script get the ID value of every page items in the active document.
      But i dont know how to save all the values [alert(("ID:" + myPgItems) in the script label.
      Trying script:
      var myDoc = app.activeDocument
      var myPageItems = myDoc.allPageItems
      alert(myPageItems.length)
      for(i=0; i<myPageItems.length; i++)
          var myPgItems = myPageItems[i].id
          alert("ID: " + myPgItems)
      Please find the attachment for more information
      Kindly give solution as soon.
      Thanks in advance
      BEGINNER
        • 1. Re: Script Label
          BEGINNER_X Level 3
          Hi All,
          Please can anyone help me for the above mentioned requirement regarding the script label.
          BEGINNER
          • 2. Re: Script Label
            Jump_Over Level 5
            Every object could has a script label and you manage this using insertLabel("key", "value") method.
            There are two parameters: "key" and "value" - both string.
            Since every label has its "key" (name) you are able to assign as many labels to an object as you want.
            You have to collect labels names cause there is no option to list these names in global.
            So to get a label value you have to know its "key".
            Method: extractLabel("key").
            Before/after alert use:
            myPageItems[i].insertLabel("ID", myPgItems.toString() )
            rgds
            • 3. Re: Script Label
              dulajun Level 2
              The property "label" differs from the data stored and extracted by "insetLabel(key, value)" and "extractLabel(key)" functions.
              But "label" property is uneditable by "script Label" panel.
              app.activeWindow.activePage.label = app.activeWindow.activePage.id.toString();
              alert(app.activeWindow.activePage.label);
              • 4. Re: Script Label
                Of course you can assign the string representation of the id number of an selected object to the label property.
                app.selection[0].label = app.selection[0].id.toString();
                The problem might be that to see the assigned label string you have to close and re-open the Script Label Panel after script execution…
                Uwe
                • 5. Re: Script Label
                  And for all page items you could use:
                  var myPage = app.activeWindow.activePage;
                  var allMyPageItems = myPage.allPageItems;
                  var myIDArray = new Array();
                  for(var n=0;n<allMyPageItems.length;n++){
                      myIDArray[n] = allMyPageItems[n].id;
                  //Sort all id numbers:
                  myIDArray.sort(function(a,b){return a-b;});
                  //You need one object that has a "label" property to assign the string.
                  //In this case a selected object (eg. a rectangle on the pasteboard).
                  //To get a string from that sorted number array,
                  //we could join it setting the delimiter to a paragraph sign, or, if you prefer, with commata, or ...
                  app.selection[0].label = myIDArray.join("\r");
                  Just as an example...
                  Uwe
                  • 6. Re: Script Label
                    But instead of the label you could also write the joined array of numbers to a text frame on the pasteboard:
                    //This time the selection is a text frame on the pasteboard:
                    app.selection[0].contents = myIDArray.join("\r");
                    Uwe
                    • 7. Re: Script Label
                      BEGINNER_X Level 3
                      Hi Laubender/Jump_Over/Junaid,
                      Thanks for your all response especially thanks for Laubender. Myself and lot of beginners are very inspired of Laubender.
                      My Requirement:
                      I want to compare two arrays using 'script label'. Is it possible in Adobe Indesign CS5. If possible means can you explain me. Because i am a beginner.
                      For example,
                      Before starting the composing my document has 8 Page items.                        //Stored as 1st array
                      After finishing composing my document has 7 or 9 Page items                        //Stored as 2nd array
                      I want to compare both the arrays using script label if any discrepancy generate REPORT.
                      or we can select a frames (app.selection[0].contents = myIDArray.join("\r");) and generate a REPORT
                      Below mentioned script are working fine:
                      var myID = new Array()
                         var IDArray = myPageItems[i].id
                           myID.push(IDArray)
                          alert(myID)
                      myID.sort(function (a,b){return a-b})
                      //~ app.selection[0].label = myID.join("\r")
                      app.selection[0].contents = myID.join("\r");
                      Thanks in advance all legends
                      BEGINNER
                      • 8. Re: Script Label
                        Marc Autret Level 4
                        Hi BEGINNER,
                        1. Why don't you store data in the document label?
                        2. To faciliate IDs comparison (new objs and/or removed ones), an object structure might be easier than an array.
                        Here is a possible approach (although not optimized):
                        function createList(/*PageItem[]*/a)
                            var i = a.length,
                                r = {};
                            while( i-- ){ r['_'+a[i].id]=null; }
                            return r;
                        function compareList(o1, o2)
                            var k, a=[], z=0;
                            for( k in o1 )
                                if( o2.hasOwnProperty(k) ) continue;
                                a[z++] = k.substr(1); // as k is in the form '_id'
                            return a;
                        function showReport(oldList, newList)
                            var r = [],
                                a;
                            r[0] = (a=compareList(newList, oldList)).length ?
                                ("NEW ids: " + a.join(" | ")) :
                                ("No NEW item.");
                            r[1] = (a=compareList(oldList, newList)).length ?
                                ("REMOVED ids: " + a.join(" | ")) :
                                ("No REMOVED item.");
                            alert( r.join("\r") );
                        // MAIN
                        var doc = app.activeDocument,
                            s = doc.label,
                            oldList = s && (new Function('return '+s)()),
                            newList = createList(doc.allPageItems);
                        if( oldList ) showReport(oldList,newList);
                        doc.label = newList.toSource();
                        alert( "Data properly saved." );
                        Marc
                        • 9. Re: Script Label
                          @BEGINNER_X – I inspected your code and it is more than unfortunate, if you are using statements that are technically working well, but sematically are misleading. For you (sometime in the future, if you'll look again on your code), for everyone else who is trying to debug your code.
                          Specifically I mean this line:
                          A variable is variable, you can nearly name it as you like, but to use a name that seems to hint, that the variable contains an Array object, when in fact it contains a Number object, that is misleading. The property "id" returns a Number.
                          And that one:
                          I just want to say: be very careful with var names in regard of semantics.
                          And don't forget the ";" at the end of every statement.
                          Believe me, this is just for security reasons.
                          Uwe
                          • 10. Re: Script Label
                            BEGINNER_X Level 3
                            Hi Mr. Laubender and Mr. Marc,
                            Thanks a lot for helping me....
                            Mr. Marc script working fine for me.
                            Mr. Laubender script helpful for my script.
                            Forum genius are always helpful and motivate  the new beginners and developers.
                            Again thanks
                            BEGINNER
                            • 11. Re: Script Label
                              BEGINNER_X Level 3
                              Hi Marc/All,
                              I  want to get master spreads pageitems  as well.
                              But the given script get pageitems from spreads not from Master Spreads.
                                  var i = a.length,
                                      r = {};
                                  return r;
                                  var k, a=[], z=0;
                                  for( k in o1 )
                                  return a;
                                  var r = [],
                                      a;
                                      ("No NEW item.");
                              // MAIN
                                  s = doc.label,
                              Please can anyone help me.
                              Thanks in advance
                              BEGINNER
