4 Replies Latest reply on Feb 5, 2013 3:28 PM by cfitzo10
    Button Interactivity Help
    cfitzo10
      Ok so I am trying to create a button that when clicked, serves two function in chronological order. So, when the button is clicked, firstly it animates and moves off the page, then, after the animation, I want the page to change to the next destinated page. Can someone give me some help on this please? I have applied these events to the button, with the animation on top of the page change, however whenever I click the button, it just changes page without the animation playing first?
      Any help is much appreciated
        • 1. Re: Button Interactivity Help
          Steve Werner Adobe Community Professional & MVP
          Is this button being used for interactive PDF, for SWF output, or for Digital Publishing Suite?
          • 2. Re: Button Interactivity Help
            cfitzo10 Level 1
            SWF Output
            • 3. Re: Button Interactivity Help
              Jeffrey_Smith Most Valuable Participant
              Although you can apply multiple events to a button, the "go to page" event will trump all others, and the animation will not be viewed. I have a workaround that involves page loads instead, and will use 2 pages:
              - On first page, have the button with the event "go to page 2" with "on click" (no animation)
              - Duplicate button, place in same position on page 2
              - Page 2 is layered like this: 1. Duplicate Button 2. Coverup 3 Contents of Page 2
              - Duplicate button will have animation triggered by page load, then moves off page
              - Using Timing Panel, have Coverup move off the page "on page load", after the animation of button finishes
              - Finally the contents of page 2 is revealed with Button and Coverup no longer on the stage
              If you would like, I can send you a file that demonstrates this workaround.
              • 4. Re: Button Interactivity Help
                cfitzo10 Level 1
                Ok thanks i'll give this a try.
                I did actually find a different workaround, by creating an invisible box that fills the whole page, that has 'go to next page' event when 'rolled over'. This box would become active 2 seconds after the inital button was clicked. Obviously that would mean that if i was to have duplicate buttons then there are lots of invisible layers and it could get confusing, so I will try your way to see what works best.
                Thanks again
