1. Re: Payment Fields Missing
Lucia Lao Feb 6, 2013 11:06 AM (in response to jodychan@legendlearning.c)Hi,
Which fields are you trying to set up for payments?
- You should be able to set up fields by choosing "2. Purchase Fields" tab in Options/Payment Processing. If you need more than one field defined, click on the "+ Assign Field" button.
- You should be able to see the choice fields (single choice, multiple choices..) and define the amount for these.
- As for the use-input field, such as when you add a text field, you should change it to 'currency' or 'number' field, for it to show as a purchase field. Go back to the Design tab, select the field and on the Field Property panel, change to 'currency' or 'number' via the drop down menu.
You may want to check this link for more information: http://forums.adobe.com/community/formscentral/payments
If this does not help, I may need to ask you to share the file with me. I'll get in touch with you directly.Thanks,
Lucia
