2 Replies Latest reply on Feb 6, 2013 7:17 AM by JP_Leya
    The update function on edge!
    JP_Leya
      Hi there!
           I'm having a little trouble on migrating from flash.
           How can i do something like:
                AS3: MovieClip(parent).addEventListener(Event.EnterFrame, doSomething);
            The logic its not the same (frames vs time), but there's a way to acomplish the same result?
           I want to call a function on a symbol, everytime is parent updates!.
      Thx
      João Ferreira
        • 1. Re: The update function on edge!
          joel_pau Level 5
          Hi João,
          You've got 3 tools:
          • Edge provides you an update panel within code panel: Stage > Timeline > Update. You put your doSomething inside the update panel.
          Note that the Update panel is available for each symbol.
          • old tool: setTimeout()
          • new tool: window.requestAnimationFrame()
          ==> Demo file: https://www.box.com/s/ryzk0oh50j8v2fi78ca8
          • 2. Re: The update function on edge!
            JP_Leya Level 1
            Hi.. thx for the help!
                 But this does not match my problem. Using your example image:
                      - I'm inside the details symbol;
                      - and from there i want to bind/create the update event of the stage.
                 Example: I have a scroll bar as a symbol, and i want to control the parent where the scroll bar is inserted. Without having to add code on the parent.. so it can be easly re-used.
                 Is it possible?
