1 Reply Latest reply on Mar 4, 2013 11:19 AM by Mandy_Wiesener
    Number problems
    csb102155 Level 1
      Hi All, I'm having problems with the how the number displays when it is calculated.  For example, 5 x 1% should read as .050.  But instead it reads 5.  How can I get it to display as .050?  I'm sure it's a simple solution, but I've yet to find it.
      Thanks all for your assistance
      Connie
        • 1. Re: Number problems
          Mandy_Wiesener Level 3
          you could make the following.
          • first field - UserEntryFieldNumber (for example 5) -
            Pattern num{zzzzzzzz9.99}
          • second field - UserEntryFieldProcent (for example 1) -
            Pattern num{zzzzzzzzzzzz9'%'} not using the the standard-%-pattern
          • target field - calculate-event
            this.rawValue = (UserEntryFieldNumber.rawValue*UserEntryFieldProcent.rawValue)/100;
          I work never with the standard procent pattern. It makes never what I want
          I hope it will helps,
          Mandy
