0 Replies Latest reply on Feb 7, 2013 5:11 AM by thinkink_es
    Compound Path - determine  winding rules
    thinkink_es
      I have a compound path, and i need to parse all points, for export to CANVAS HTML , for this I wrote this script:
      But the problem is how to detect the holes. I find information, and i think that i need the fill rule or clockwise fill, but in the reference doesn't exist.
      Somebody can help me. Thanks
      Compound Path fill rules:  http://forums.adobe.com/message/4507598?tstart=0#4507598
      Nonzero winding fill rule
      Uses mathematical equations to determine if a point is outside or inside a shape. Illustrator uses the nonzero winding rule as the default rule.
      Even-odd fill rule
      Uses mathematical equations to determine if a point is outside or inside a shape. This rule is the more predictable rule because every other region within an even‑odd compound path is a hole, regardless of path direction. Some applications, such as Adobe Photoshop, use the even‑odd rule by default, so compound paths imported from these applications will use the even‑odd rule.
      http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e07d0100196cbc5f-6462a .html#WS714a382cdf7d304e7e07d0100196cbc5f-644ea
      http://www.fireworkszone.com/tuts/476/fill_rules.pdf
      /*bool*/ Polygon.prototype.collideShapes = function(/*Polygon*/ _poly)
      // Ret. TRUE if the shapes intersect
      // slow method
      try {
           this.intersectPath(_poly);
           app.activeDocument.undo();
           return(true);
      catch(ex)
           return(false);
      var selection = app.activeDocument.selection;
      var a= selection[0]
      var b= selection[1]
      //alert( a.collideShapes(b))
      function inArray(agulla, paller){
          var length = paller.length;
          for(var i = 0; i < length; i++) {
              if(paller[i] == agulla) return true;
          return false;
      var item  = app.activeDocument.selection;
      var items = item[0].releaseCompoundPath();
      var restantes = items;
      var groups={}
      var i = items.length;
      //          while( i-- )
      for (var i=0;i< items.length;i++)
                          a = items[i];
                          try{
                          $.writeln( items[i].LocalDisplaySetting          )
                          }catch(e){$.writeln( e)}
      for (var s=0;s< restantes.length;s++){
      var b = restantes[s]
      if(a!=b){
      if(inArray(b, restantes)== true){
      try{
      if(a.collideShapes(b)){
      if(typeof groups[i]== "undefined"){
      groups[i]=[]
      groups[i].push(i)
      groups[i].push(s)
      restantes[i]= "void";
      items[i]= "void";
      restantes[s]= "void";
      items[s]= "void";
      catch(e){}
      for (var t=0;t< restantes.length;t++){
      if(restantes[t]!= "void")
      $.writeln ( "_" + t +",");
      for(var g  in groups){
      var group = groups[g]
      $.writeln ("var compoundPath = new CompoundPath( _" + group.join(", _") +").fillColor = 'red';");
