11 Replies Latest reply on Apr 29, 2013 7:49 AM by Mylenium
    Textures in Element 3D - Help!
    Dynopete
      I imported a 3D object (.obj) in Element 3D. I applied a metalic texture to the object. Here's my question: My final object should have a metalic texture with a big color label on it (imagine a metal paint can with a paper label around it). Is there a way to apply the metal texture to the object and then the imported label texture on top?
        • 1. Re: Textures in Element 3D - Help!
          No. Element's texturing is quite limited. You would have to combine the layers in Photoshop and create matching specularity maps etc. to get different shading behavior in different areas.
          Mylenium
          • 2. Re: Textures in Element 3D - Help!
            Dynopete Level 1
            Do you think it's possible to import the two objects independately and then assemble them together?
            • 3. Re: Textures in Element 3D - Help!
              Sure. If they are reasonably aligned already, you can add as many objects to a group as you like and possibly do a bit of aligning by adjusting the anchor point and scale in teh editor, if needed. Of course you can always also use 2 groups and align them that way. Just be clear that this doesn't change the rules for texturing: Even if you use this approach, Element will not render transparencies, so if your label is anything else but a square/ cylinder segment, any contours will have to be geometry based so the parts outside are "cut away". just using a texture with transparency won't work.
              Mylenium
              • 4. Re: Textures in Element 3D - Help!
                Dynopete Level 1
                Thanks Mylenium. Actually, the label will cover the entire paint can itself. The problem is the lid. I first imported the paint can, and then when I tried to import the lid, the can disapeared and I could only see the lid in the window. It's probably a "group" problem, no? Then, are you saying I can align these object in the Element 3D window?
                • 5. Re: Textures in Element 3D - Help!
                  You need to set the particle count accordingly - 2 in your case. Each element counts as a particle and if there are more particles than elements, they will be repeated. Unfortunately there's no way to do this visually, because only the currently selected object shows in teh editor viewport, so a bit of experimentaion may be required, if you didn't model your items with teh same origin.
                  Mylenium
                  • 6. Re: Textures in Element 3D - Help!
                    Dynopete Level 1
                    Here are the steps I took. Let me know where I go wrong. I load Element into a new Solid layer. I click on Scene Setup. The Scene Setup window opens. I import a first element, the paint can (in group 1). I import a second element, the lid (in group 1 also). When I click OK and go back to my Comp, I set the Particle Count to 2 and I see that the lid is in the middle of the paint can. I need to move it up on top of the can.  Of course, changing the Position XY moves the entire group, not just the lid. So my question is, can I move the lid up in the Scene Setup window? If so, how? Thanks!
                    • 7. Re: Textures in Element 3D - Help!
                      Yes, enable the grid preview in the editor window amd then select the element in the list. Then adjust the anchor point which will be visualized as the origin of the grid. Requires Element 1.5, so download this free update, if you haven't already.
                      Mylenium
                      • 8. Re: Textures in Element 3D - Help!
                        Dynopete Level 1
                        Thanks. I will update the plugin. One last question and then I leave you alone. I watched the 1.5 update official video on Videocopilot. The guy imports a 3D character (soldier). He then gives it textures. We see that the face has one texture, so does the uniform, the shoes. etc. How is this done? How do you give the same onject all of these tectures?
                        • 9. Re: Textures in Element 3D - Help!
                          You can apply different textures to selections in contiguous meshes, which will then appear as separate materials. E.g. if you had created your paint can as a single lump, but created a polygon selection for the lid and possibly applied a different material to this selection, it would show up this way and could be textured separately.
                          Mylenium
                          • 10. Re: Textures in Element 3D - Help!
                            sozm84982426
                            hello   - i am using element 3d and i  have  all models pack but i have a  problem   when i use  element 3d   i see that my  3rd party models   have  no textures  on them
                            and i really  want to use those models
                            i work for TV anyone help me !!!!!
                            • 11. Re: Textures in Element 3D - Help!
                              Put them in your model library folder or in the folder where you store the Elemnt project. The plug-in automaticalyl looks for everything in these locations...
                              Mylenium
