This content has been marked as final.
Show 2 replies
1. Re: Actionscript PROBLEMS
clbeech Nov 17, 2007 2:43 PM (in response to Mary_Alice)Mary, both of those methods are suppose to be within the on(release) handler, it looks as though you've added a } after the 'my_lv.email = ...' statement, remove that bracket, this is the reason for all of the above errors.
this is the way the code is constructed in the original post:
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=15&catid=288&threadid =1315529&enterthread=y -
2. Re: Actionscript PROBLEMS
Newsgroup_User Nov 17, 2007 2:49 PM (in response to Mary_Alice)Mary Alice,
> This is the error message that comes:
> **Error** Scene=Scene 1, layer=SUBMIT , frame=1:Line 29:
> Statement must appear within on/onClipEvent handler
That message, "Statement must appear within on/onClipEvent handler,"
means that you have directly attached your code to an object of some kind --
a button, perhaps, or a movie clip -- without putting that code inside
either an on() or onClipEvent() handler. There are at least two places to
put your code in a Flash document (not counting external scripts, which is
yet another possibility): you can A) put code in the keyframe of a timeline
or B) attach it directly to an object (in ActionScript 1.0 or 2.0
documents).
The selected item determines the placement of your code. If you've
clicked a keyframe to select it, then the Actions panel is associated with
the timeline. If you've clicked a button (etc.) to select it, then the
Actions panel is associated with that object. Any code that appears on an
object, such as a button, must be contained within one or more of the
following sorts of statements:
on (press) {
// code here
on (release) {
// code here
// etc.
... which indicates when the code should execute; that is, in response to
what event (being pressed by the mouse, being released, and so on). The
code you've shown is not entirely contained within your on() handler. If it
were, it might look like this:
on (release) {
my_lv = new LoadVariables();
my_lv.household = _parent.household_txt.text;
my_lv.water = _parent.water_txt.text;
my_lv.soft = _parent.soft_txt.text;
my_lv.bottle = _parent.bottle_txt.text;
my_lv.comments = _parent.comments_txt.text;
my_lv.namebus = _parent.namebus_txt.text;
my_lv.address1 = _parent.address1_txt.text;
my_lv.address2 = _parent.address2_txt.text;
my_lv.phone = _parent.phone_txt.text;
my_lv.email = _parent.email_txt.text;
re_lv.onLoad = function(success) {
if (success) {
getURL(" http://www.ecowaterpb.com/thanks.html");
my_lv.sendAndLoad("analysisformphp.php", re_lv, "POST");
Note very carefully how every "{" character has a closing "}" character,
even when "{}" pairings are nested within each other.
David Stiller
Co-author, Foundation Flash CS3 for Designers
http://tinyurl.com/2k29mj
"Luck is the residue of good design."
