1 Reply Latest reply on Feb 8, 2013 1:48 AM by George_Johnson
    Parse a multi-line file?
    TechnoGeek Level 1
      Is there a way to get the lines from a multi-line text field into an array - one array element per line?  Each line in the text field ends with one delimiter character (say <CR> or ';'), but that character should not be part of the array element. So:
      Multi-line text field:
      dog
      cat
      bird
      bat
      horse
      Becomes
      a[0]="dog"
      a[1]="cat"
      a[2]="bird"
      a[3]="bat"
      a[4]="horse"
      This would be with Acrobat XI.
      If the array created is used to populate other text fields, would that work under Adobe Reader?
        • 1. Re: Parse a multi-line file?
          George_Johnson MVP & Adobe Community Professional
          Yes, it will work with Reader. There is a carriage return at the end of each line of a multiline text field, so you can just to this:
          var aRows = getField("multiline1").valueAsString.split(/\r/);
          But note that if one line wraps to another, there won't be a carriage return at what appears to be the end of the first line.
