1 Reply Latest reply on Nov 13, 2017 11:49 AM by Kris1979
    Socket POST connection close
    bduffy323 Level 1
      Hello all,
      I was wondering if there was a way to close a connection once the server writes back to the connection? I have this post:
      var conn = new Socket;
      //conn.timeout = 300;
      //conn.timeout = 10;
      conn.timeout = 2;
      var tempzzz = $.hiresTimer;
      conn.open(vHost);
      conn.write("POST " +vSubDir+"/update.asp HTTP/1.1\r\n");
      conn.write("Host: " + vHost + "\r\n");
      conn.write("Content-Length: " + data_string.length + "\r\n");
      conn.write("Content-Type: application/x-www-form-urlencoded\r\n");
      conn.write("\r\n");
      conn.write(data_string);
      var reply = "";
      reply = conn.read(999999);
      conn.close();
      var myTime = $.hiresTimer/1000000;
      alert("found reply "+myTime)
      When I run this code with the timeout set to 2 my alert states found the reply in 1.75 sec.
      When I run this code with the timeout set to 10 my alert states found the reply in 9.87 sec.
      When I run this code with the timeout set to 300 my alert states found the reply in 126.23 sec.
      Any idea how to close the connection and therefore make indesign active again the moment a server replies? I cannot use a get because I am sending a lot of data to the server which would exceed the URL size limit. Any information would be helpful, thanks!
        • 1. Re: Socket POST connection close
          Kris1979
          Well.... Seems quite post apocalyptic in here, but here's my reply for those interested:
          conn.open(vHost);
          conn.write("POST " +vSubDir+" HTTP/1.1\r\n");
          //Try this one:
          conn.write("Connection: close\r\n");
          conn.write("\r\n");
