0 Replies Latest reply: Feb 8, 2013 10:39 AM by KJSTech RSS
    Need Acrobat 9 Std LEID for APTEE tool replace sn after imaging
    KJSTech Community Member
      Hello,
      I need the LEID for Adobe Acrobat 9 Std for the APTEE tool.  The syntax is this:
      adobe_prtk --tool=ReplaceSN --serialize=LEID --serial=serial
      What does work on Acrobat X Std is AcrobatStd-AS1-Win-GM
      I have a disk image that has Acrobat 9 which is required for the Dell computers that came with Acrobat 9 and this command produces a return code = 6 which I think means product LEID is not found on the computer.
      After restoring a disk image it is important to run this tool (which is installed on the computer prior to SYSPREP).  This way we can put the correct SN that came with that hardware so that end users are not badgered by a licensing screen.
      I am not sure if this worked, despite return code 6.  I still haven't gotten a pop up and I've had a PDF open now for over 10 minutes.
