4 Replies Latest reply on Feb 11, 2013 7:26 AM by asmcleod
    Layers to files: replace spaces with underscores
    asmcleod
      How can I update the script to replace spaces with underscores on export? I assume I need to add a line somehwere between 183-195 but I don't know what it needs to be. Thanks in advance.
        • 1. Re: Layers to files: replace spaces with underscores
          Where did you get the Layers to files script. Photoshop versions ship with a "Export Layers To Files.jsx" CS6 lines 183-195 look like this I see nothing about filename
            var layerSetsCount = app.documents[docName].layerSets.length;
                   if ((layerCount <= 1)&&(layerSetsCount <= 0)) {
                      if ( DialogModes.NO != app.playbackDisplayDialogs ) {
                          alert( strAlertNeedMultipleLayers );
                                  return 'cancel'; // quit, returning 'cancel' (dont localize) makes the actions palette not record our script
                  } else {
                      var rememberMaximize;
                      var needMaximize = exportInfo.psdMaxComp ? QueryStateType.ALWAYS : QueryStateType.NEVER;
                      if ( exportInfo.fileType == psdIndex && app.preferences.maximizeCompatibility != needMaximize ) {
                          rememberMaximize = app.preferences.maximizeCompatibility;
          • 2. Re: Layers to files: replace spaces with underscores
            Line  1029-1032 in Export Layer to Files look more like what you may be looking for. You may be able to add " " to line 1032 I do not know regular expression syntax this may work  (/[:\/\\*\?\"\<\>\|\ ]/g, "_")
                   var fileNameBody = fileNamePrefix;
                    fileNameBody += "_" + zeroSuppress(i, 4);
                    fileNameBody += "_" + layerName;
                    fileNameBody = fileNameBody.replace(/[:\/\\*\?\"\<\>\|]/g, "_");  // '/\:*?"<>|' -> '_'
            • 3. Re: Layers to files: replace spaces with underscores
              conroy Level 5
              In line 1032, insert a backslash and space immediately before the characters ']/g'.
              Also insert a space in the equivalent location of the comment for completeness.
              The result will look like:
              • 4. Re: Layers to files: replace spaces with underscores
                asmcleod Level 1
                I was looking in the wrong script. I had the Layer COMPS to files script, but you are all correct. I need the Export Layers to Files script. Thanks for the responses.
