3 Replies Latest reply on Feb 13, 2013 10:06 AM by Akradon360
    CS6 Multi-cam...multi audio?
    Akradon360
      Now I can't seem to figure this out for the life of me. Me and my friends have tried to do a 'lets play' type of video. So we have 3 different recordings of Xbox screens (done via HD-PVRs) which have 3 seperate audios. But using the multi-cam setting I can only get one of the audios to play or all 3 at the same time so it sounds like a mess.
      How do I get it (if there's a way) to play the correct audio to the video currently being shown? I have gone into the sequence and toggled the track output on all 3 audios. Ticked and unticked the 'audio follows video' option inside the multi-cam screen, but to no avail?
      I'm not sure if I'm just missing something or that it can't be done. Any help will be appriciated.
        • 1. Re: CS6 Multi-cam...multi audio?
          justdohnut Level 1
          I've been a longtime Premiere user, but hadn't needed to delve deeper into Multicam sequences until a project I started today. I spent all morning and ran into the same limitation you described. Now that I've discovered a solution, I've been posting replies to all the threads that have had this issue, so someone searching for the solution like I did this morning may see it too!
          Using screenshots and putting text together using Photoshop, you can view my workaround here:
          The first step is creating your Multi-Cam sequence properly:
          https://dl.dropbox.com/u/38225717/Multi-camCS6_1.png
          The second step is duplicating the multi-cam sequence's audio onto separate tracks, then enabling Multi-Camera on the audio. You then switch each audio to the corresponding track number.
          Hopefully that makes more sense in the image:
          https://dl.dropbox.com/u/38225717/Multi-camCS6_2.png
          It's not perfect by any means, and it's a little messy, but it'll get the job done. For me, it was a necessity as I am cutting scenes and may need to mute the boom track, adjust levels on a lav track, etc.
          I hope my diagrams make sense; I sorta cobbled them together quick because I really wanted to share it with the Adobe community before heading back to work!
          • 2. Re: CS6 Multi-cam...multi audio?
            Jim_Simon Level 8
            Toggle only track 1 in the multicam sequence and then check Audio Follows Video.
            • 3. Re: CS6 Multi-cam...multi audio?
              Akradon360 Level 1
              Thanks for the reply. Will try this when I next get some footage to sync up. I've tried it quickly with 3 random files but couldn't get it to work. I may have missed something since I sped through it though.
