5 Replies Latest reply on Sep 11, 2006 2:11 PM by saldillo
    LoadVars always undefined when viewing uploaded movie
    saldillo
      Hello,
      I created a flash movie that has a "Contact us" form, that sends name, email, phone number and comments to an ASP.NET web page that acts as an email relay. If it is able to contact the ASP page, then it displays a "success" message. If it is unable to contact the server or if the ASP page returns an error, then it displays an "error" message.
      When I test the movie on my computer (be it directly from Flash or from a webpage in my hard drive) it does what it's supposed to do: send the contact info to the webserver and then display a "success" or "error" message, but when I upload the movie to a server (even a local server) it always returns "undefined". I have already tested it on 4 different servers (including the local server) and it always behaves the same.
      What am I missing that causes this behavior?
      Thank you for any help that you may provide.
        • 1. Re: LoadVars always undefined when viewing uploaded movie
          WebXperience Level 1
          Be sure that the data file that you are loading with LoadVar has the correct path. On your hard drive the file might be in a subdirectory, so either create a directory on your server with the same name or place the data file in the same directory as the swf.
          • 2. Re: LoadVars always undefined when viewing uploaded movie
            Level 7
            I always create a quick HTML page to send the data to the server script in
            these cases and see what I get back outside of Flash. Sometimes it is a
            install configuration issue having nothing to do with Flash.
            Lon Hosford
            www.lonhosford.com
            Flash, Actionscript and Flash Media Server examples:
            http://flashexamples.hosfordusa.com
            May many happy bits flow your way!
            "saldillo" <webforumsuser@macromedia.com> wrote in message
            news:ed5k22$ggp$1@forums.macromedia.com...
            > Hello,
            > email,
            > relay.
            > message. If
            > then it
            > contact
            > when
            > the
            • 3. Re: LoadVars always undefined when viewing uploaded movie
              saldillo Level 1
              Yup, I already did that.
              I created a basic HTML page that has a bunch of hidden fields that represent the data being sent by the flash movie. I uploaded it to the same server where I uploaded the SWF to see if it had anything to do with the server but alas, when I press the submit button on the HTML page it shows the OK message that is being sent by the ASP page, and I received the email just fine.
              I never receive the email when I press the submit button on my uploaded SWF movie, which leads me to believe that the ASP page is not receiving the information.
              I'm attaching my AS code, I forgot to do so in my original posting.
              Thank you for your replies.
              • 4. Re: LoadVars always undefined when viewing uploaded movie
                Level 7
                1. Place last
                email.sendAndLoad(' http://www.promocasa.com.mx/tools/formaCorreo.aspx',
                emailResponse, "GET");
                You have a potential timing issue where emailResponse.onLoad =
                function(success:Boolean) is not assigned before the response is registered.
                something = function is a run time assignment and needs to be processed
                before it has potential to be used.
                2. Did you try "POST" instead of "GET"?
                3. Is Flash Movie on the same domain as www.promocasa.com.mx. If not you
                need a crossdomain.xml file.
                4. Try a very basic Flash movie that simply sends and receives some static
                data from your server.
                5. Add some traces to the emailResponse.onLoad
                trace ("emailResponse.onLoad - succes:"+success);
                6. Be sure you do not have a cached old version of the Flash movie in your
                web browser. A quick way is to rename it temporarily and upload.
                7. Not sure about your scoping since it works locally, but for a test define
                var email:LoadVars = new LoadVars();
                var emailResponse:LoadVars = new LoadVars(); on the timeline and comment
                inside the on(click)
                Lon Hosford
                www.lonhosford.com
                news:ed70m3$6ei$1@forums.macromedia.com...
                > represent
                > where
                > alas,
                > that is
                > SWF
                > information.
                > on (click) {
                > // This is the data that the user entered in the contact form.
                > email.txtNombre = _parent.txtNombre.text;
                > email.txtEmail = _parent.txtEmail.text;
                > email.txtTelefono = _parent.txtTelefono.text;
                > email.txtComentarios = _parent.txtComentarios.text;
                > // My ASP page should work for any SWF movie so I put this here for each
                > movie that
                > // sends data to the server. Once I get this working the way it
                > should, I'll load the info from a text file to
                > // avoid hard coding it in the movie.
                > email.txtEmailReceptor = "aldo.herrera@promocasa.com.mx"; // Who should
                > receive the email
                > email.txtEmailEmisor = "contactos@barcelonaresidencial.com.mx";
                > email.txtDesarrollo = "Barcelona Residencial"; // What webpage
                > originated
                > this request
                > email.txtAsunto = "BARCELONA: Forma de contacto del sitio web Barcelona
                > Residencial"; //Subject
                > email.txtMensaje = "Se ha recibido una petici?n de informaci?n del sitio
                > web
                > Barcelona Residencial."; //
                > emailResponse,
                > "GET");
                > emailResponse.onLoad = function(success:Boolean) {
                > var strSuccess:String = "?Gracias por tu inter?s! Uno de nuestros
                > asesores
                > recibi? tu petici?n y se pondr? en contacto para atenderte.";
                > var strError:String = "Lo sentimos. Hubo un error t?cnico al enviar tu
                > informaci?n. Por favor cont?ctanos por tel?fono para poder atenderte.
                > Disculpa
                > las molestias.";
                > var strMensaje:String = this.mensaje;
                > if ( success) {
                > _parent.estado_txt.text = strMensaje; // Print the message to a
                > dynamic text field called "estado_txt"
                > _parent.nextFrame(); // This removes my input form and shows the
                > estado_txt field.
                > if ("OK" == strMensaje.substr(0,2) )
                > _parent.estado_txt.text = strSuccess;
                > else
                > _parent.estado_txt.text = strError;
                • 5. Re: LoadVars always undefined when viewing uploaded movie
                  saldillo Level 1
                  Thank you very much! #3 Solved the problem, and I did #1 just in case. You were a big help.
                  Best regards,
                  Aldo
