1 Reply Latest reply on Feb 11, 2013 3:05 PM by peterswan
    cfexecute with multiple arguments
    peterswan Level 1
      Hello,
      I'm trying to encrypt a file with CFEXECUTE, using OpenSSL. When I run the code in the command prompt, it works fine and the new encrypted file appears in the correct folder. Also, I can run CFEXECUTE with OpenSSL with just one argument and it works fine. ie arguments="version". But the following does not return a value, nor does it create the new folder:
      <cfexecute name = "C:\Program Files (x86)\GnuWin32\bin\openssl"
          arguments = "aes-256-cbc -a -salt -in ""C:\Users\Dev2\Documents\My Stuff\OpenSSL\secrets.txt"" -out ""C:\Users\Dev2\Documents\My Stuff\OpenSSL\secrets2.txt"""
          variable = "result"
          timeout = "5">
      </cfexecute>
      <cfdump var="#result#">
      Any ideas?
      Pete
        • 1. Re: cfexecute with multiple arguments
          peterswan Level 1
          BYW,
          This runs fine:
              arguments = "list-standard-commands"
              variable = "result"
              timeout = "5">
          </cfexecute>
          and so does this:
              arguments = "version"
              variable = "result"
              timeout = "5">
          </cfexecute>
          Maybe someone has a multiple argument example of CFEXECUTE that runs fine.
          I'd be interested to know.
          Pete
