I have installed Adobe Flash and its Plug-in but Mozilla does not recognize that I have done this. My OS is Vista Ultimate 64-Bit. Also, it seems that Adobe points to a 32-Bit file to download instead of a 64-Bit file.
How does Mozilla (Firefox?) not recognize the Flash Player plugin; is it not listed under plugins (Shockwave Flash)?
Also, if you use Firefox, which is a 32-bit browser, it will use the 32-bit plugin. If you use a 64-bit browser like Waterfox, it will use the 64-bit plugin.
What files do you have in C:\Windows\system32\Macromed\Flash ?
[topic moved to Flash Player forum]
Yes it is listed under plug-ins.
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html
That URL in Mozilla will not allow me to open up the configuration. Flash does still work though with IE. When I uninstalled Flash and the plug-in, it removed the 64-bit versions but when I went to reinstall, Adobe’s site gave me the option only to install a 64-bit version of the plug-in. As we know, Mozilla is 32-bit.
The file names in the flash folder you requested are:
activex.vch,Flash64_11_5_502_149.ocx,
FlashInstall, FlashUtil64_11_5_502_149_ActiveX, FlashUtil64_11_5_502_149_ActiveX, FlashUtil64_11_5_502_149_Plugin, NPSWF64_11_5_502_149,
plugin
The 32-bit plugin is installed in C:\Windows\syswow64\Macromed\Flash.
You’re right, the files are in that folder so why isn’t Mozilla recognizing that they’re there?
