2 Replies Latest reply on Feb 10, 2013 12:09 PM by One Horse
    Is there a way to set playback speed?
    One Horse
      I would like to play a symbol in reverse at twice the original speed. Is this something that is possible without a whole lot of code.
      I tried "sym.playReverse();" by trying different  numbers. Any and all help appreciated.
      Greg....
        • 1. Re: Is there a way to set playback speed?
          drsqueegee
          I wish there was an easy way to do that too. I can think of a way to create the illusion of double speed reverse with the use of triggers and labels.
          1. create your forward animation
          2. place start label
          3. place end label
          4. when symbol timeline is at the end copy the animation
          5. paste (special, inverted)
          6. place start and end labels on inverted animation
          7. squash time on inverted animation to half of the forward one
          Now if you play from the label "start inverted" it will be playing your original animation in reserse at twice the speed. You can add what ever stop triggers etc. that you need to make it work right.
          Will that work for you?
          • 2. Re: Is there a way to set playback speed?
            One Horse Level 1
            Thank you. That will surely work.
