2 Replies Latest reply on Feb 10, 2013 7:33 AM by Gaguilar2099a
    Need refresher on date+1
    Gaguilar2099a
      I know this is an easy on, so I thought, need the simple script to add 1 day to a second date field. I have datefield with 2/12/13 need datefield2 to calc/add 1 day: to = 2/13/13. I have tried what I had and couple that were posted here but nothing happens in the second date field. Thanks
        • 1. Re: Need refresher on date+1
          George_Johnson MVP & Adobe Community Professional
          There are several ways to do this. One way is to use a custom Validate script in the first text field, something like:
          //Custom Validate script
          (function () {
              // Clear other field if field is blank
              if (!event.value) {
                  getField("datefield2").value = "";
                  return;
              // Convert value to a date object
              var d = util.scand("mm/dd/yyyy", event.value);
              // Add one day
              d.setDate(d.getDate() + 1);
              // Set the value of the other date field
              getField("datefield2").value = util.printd("mm/dd/yyyy", d);
          • 2. Re: Need refresher on date+1
            Gaguilar2099a Level 1
            Thank You! I see where I was messsing up and learned a couple of other things as well! Thanks again!
