5 Replies Latest reply on Feb 10, 2013 11:39 AM by try67
    Folder level script? How can I use field value as a pdf filename in save as dialog box
    TechnoGeek Level 1
      I read somewhere that if you use a folder level script, you can do things like save a pdf with a specific filename - possibly based on a field name.
      How would one set up a folder level script?
      How do you execute a script from the PDF?
      What code would you use to change the PDF name to the contents of the fFieldName text field?
      Or, is this really just impossible to do?
