1 Reply Latest reply on Nov 21, 2007 8:41 AM by Lăcră Ene
    Flex 3 CSS editor crashed with Oxygen 8.2+ plugin loaded
    netsesame Level 1
      I installed both Flex 3 M3 and Oxygen 8.2 in my Eclipse IDE plugins. They all run well with each other. However, when I want to open a css file with flex 3's CSS editor, an Error dialog jumped, which says:
      org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
      at org.eclipse.jface.util.Assert.isTrue(Assert.java:185)
      at org.eclipse.jface.util.Assert.isTrue(Assert.java:170)
      at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.setActivePage(FlexMu ltiPageEditorPart.java:569)
      at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.setActivePage(CodeAndDesi gnEditor.java:621)
      at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.createPartControl(Fl exMultiPageEditorPart.java:235)
      at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.createPartControl(CodeAnd DesignEditor.java:140)
      at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:661)
      at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:426)
      at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:592)
      at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:299)
      at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:179 )
      at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFo lder.java:268)
      at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder .java:65)
      at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStack Presentation.java:400)
      at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
      at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
      at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1604)
      at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
      at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
      at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
      at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
      at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
      at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:217)
      at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:207)
      at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:774)
      at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:673)
      at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:634)
      at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2719)
      at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2633)
      at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPage.java:2625)
      at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2577)
      at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
      at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2572)
      at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2556)
      at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:340)
      at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.java:328)
      at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMenu.java:190)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:153)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:504)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
      then the UI stopped.
      If I restart Eclipse IDE without load Oxygen 8.2+, the Flex CSS editor will work fine without any question.
      I really wonder how to resolve such issue.
      Please help. thanks.
