4 Replies Latest reply on Feb 21, 2013 2:06 PM by Gernouille
    Random Delete tool with Scriptographer
    Gernouille Level 1
      Hi, I am trying to refine the RandomTools created for Scriptographer so that it suits my preference, but I can't figure it out in Javascript. Not knowing a lot of Javascript don't help me either!
      Here is the script, simplified to conserv only the Delete part. What I would like to do is to enter a percentage, and then this would be the percentage of selected object removed.
      If anyone would point me to a direction with that, It would be really great.
       *  randomDelete 0.4
       *  Base on
       *  Ken Frederick
       *  ken.frederick@gmx.de
       *  http://cargocollective.com/kenfrederick/
       *  http://kenfrederick.blogspot.com/
       *  Modified by Jolin Masson
       *  http://jolinmasson.com/
       *          this script uses stuff borrowed from keegan's "rando-color.js"
       *          as well as from some other things i had written in processing
      script.coordinateSystem = 'bottom-up';
      script.angleUnits = 'radians';
      var sel;
      var values = {
                b_delete: true,
                val_deleteAmt: 2,
      // gui components
      var components = {
                b_delete: {
                          onChange: function(value) {
                                    components.val_deleteAmt.enabled = value;
                val_deleteAmt: {
                          type: 'number',
                          fullSize: true,
                          enabled: true
                deleteRule: {
                          type: 'ruler',
                          fullSize: true,
                submit: {
                          type: 'button',
                          value: 'Apply',
                          onClick: function() {
                                    Main();
      // Setup
      function Setup() {
                // initialize the palette window
                var palette = new Palette('Random Delete 0.5', components, values);
      // Update
      function Update() {
      // Main
      function Main() {
                // document properties
                sel = activeDocument.getItems( { type: Item, selected: true } );
                //adjust delete range values based on selection number
                components.val_deleteAmt.range = [0, sel.length-1];
                // loop through selected items
                for ( i in sel ) {
                          var object = sel[i];
                          if( object.isValid() ) {
                                    // delete
                                    if ( values.b_delete ) {
                                              rand = parseInt( Math.random()*values.val_deleteAmt );
                                              if (rand == 0) object.remove();
                          } //end isValid()
      } //end Main()
      // methods
      function random(minr, maxr) {
                return minr + Math.random() * (maxr - minr);
      // execution
      Setup();
      Update();
