4 Replies Latest reply on Feb 12, 2013 3:32 AM by Belle7777
    Add item to ListBox in PDF
    Belle7777
      I have a listbox named INFORMATION in a PDF that I need to populate with data from elsewhere and display the same.
      I know how to set the values for a text field
      oDoc.getField("TextFieldName").value = "ABC";
      How do I do an addItem for a ListBox field where I need to keep adding items to the ListBox field?
      Help appreciated.
      Thanks.
        • 1. Re: Add item to ListBox in PDF
          You cannot add items to a list box directly.
          You can use the insertItemAt or setItems methods to modify a list box or combo box.
          This can only be done with Acrobat unless you provide a PDF with Extended Reader Rights.
          Here is a working example of using the instertItemAt, you may need to change the field name:
          var oLB = this.getField("List Box1");
          var nItems = oLB.numItems ;
          oLB.insertItemAt("ann", "a", 0); /* inserts sam at top of list */
          oLB.insertItemAt("sam", "s", oLB.numItems); /* inserts sam at end of list */
          And for the setTiems:
          var aItems = new Array(["ann", "a"], "b", "c", ["sam", "s"]);
          oLB.setItems(aItems);
          • 2. Re: Add item to ListBox in PDF
            You can't add a single item to a list, but you can set the entire list of
            items, using the setItems() method.
            You can also use the numItems property and getItemAt method to get a list
            of the current items, then add the new items to it.
            • 3. Re: Add item to ListBox in PDF
              Belle7777 Level 1
              Thank you all!  I was able to use the setItems() method to set all the values to the list box at once.
              Could anyone please share with me a link to the comprehensive list of acrobat related javascript information with respect to field types?
              • 4. Re: Add item to ListBox in PDF
                Belle7777 Level 1
                A related question:
                The ListBox shows the first item highlighted as the selected Item.  Since my PDF is going to be for display only (non editable), I need to deselect the default selected Item.
                Can someone tell me how I can do that in Javascript?
                Thanks.
