4 Replies Latest reply on Feb 11, 2013 1:41 PM by Helen22
    Photoshop CS5 keeps crashing on start up
    Helen22 Level 1
      Running Windows 7 64 bit, has been fine up until a few days ago after I had a virus.  I have uninstalled, used the photoshop clean up tool and reinstalled, still the same problem. CS4 is working fine but I can't get CS5 to work, it crashes on start up with the following details.
      Problem Event Name:APPCRASH
        Application Name:Photoshop.exe
        Application Version:12.0.0.0
        Application Timestamp:4bbc5b10
        Fault Module Name:amtservices.dll
        Fault Module Version:3.0.0.64
        Fault Module Timestamp:4b6004a6
        Exception Code:c0000005
        Exception Offset:0000000000088dba
        OS Version:6.1.7601.2.1.0.768.3
        Locale ID:2057
        Additional Information 1:42f3
        Additional Information 2:42f36e6d42b7acab1a756482c3a16e17
        Additional Information 3:a3a2
        Additional Information 4:a3a2bc05e7527151873d6c51f844212f
        • 1. Re: Photoshop CS5 keeps crashing on start up
          Level 7
          First, go download and install all the Photoshop updates.
          • 2. Re: Photoshop CS5 keeps crashing on start up
            Helen22 Level 1
            Just tried it but still having the same problem:
              Application Version:12.0.4.0
              Application Timestamp:4d9d8f8e
              Locale ID:2057
            • 3. Re: Photoshop CS5 keeps crashing on start up
              Level 7
              OK, updating rules out a lot of issues.
              Since you just repaired a virus/malware infestation -- most likely some of your files are corrupt.
              Now the most likely cause is a corrupt activation database file.
              Second most likely cause is a corrupt DLL.
              I would have thought that running the cleaner tool and reinstalling would clean out all the related files (database and DLL).
              You probably need to talk to the install/activation folks to see what might be going wrong with the activation DLL (we can't really help with that from the Photoshop side of things).
              • 4. Re: Photoshop CS5 keeps crashing on start up
                Helen22 Level 1
                Would it be easier to repair windows and try again, or if I have to, re-format and reload windows then try again? I only use my laptop for downloading photos at events so won't loose anything critical.
