1. Re: livepkgr m3u8 and f4m out of sync
Apurva Udaykumar Feb 12, 2013 10:04 PM (in response to CarphuntinGod)Hi,
HLS stream in general will have a delay of about 24 seconds, while it is lesser for an HDS stream depending upon the fragment and segment durations. Hence the sync issues between the two.
Apurva
2. Re: livepkgr m3u8 and f4m out of sync
CarphuntinGod Feb 13, 2013 7:52 AM (in response to Apurva Udaykumar)is there a way to lessen this in any way?
I'm mainly concerned about some audio streams I want to run. Not sure yet if they will be single or multi bit rate, but I'd like to attempt to do what I can to keep the streams with as little delay from the source signal as possible.
Maybe buffering settings, etc. in the conf files or anything like that able to help?
3. Re: livepkgr m3u8 and f4m out of sync
SE_0208 Feb 18, 2013 2:42 AM (in response to CarphuntinGod)If i am not wrong you are more concerned about delay for HDS as well as HLS streams and not about keeping HDS and HLS both in sync. Anyways you can try to keep both settings same, like keeping fragment duration and hls media duration of same value , by default fragment duration is 4 and hls media duration is 8. You can make them both as 4 though Apple recommends to have it as 10. This is from server end. From client end , I am not sure whether OSMF has strict restiction like IOS client of having minium 3 fragment entries in playlist. But in iOS client you would have delay of around 12 seconds or more because that's how iOS client behaves.
4. Re: livepkgr m3u8 and f4m out of sync
Michael Kennedy (12345) Feb 18, 2013 3:10 AM (in response to CarphuntinGod)You can set the OSMF pureLiveOffset parameter in your player to delay the HDS stream.
I'm not sure there is any real value in attempting to get all output formats to be in sync. The broadcast world does not keep their outputs in sync, and unless you have a special audience they probally don't know that there is a delay already. Watch the satellite feed of a game the next time you are at a stadium to see what I mean. Do you currently keep your FM/DAB broadcasts in sync?
5. Re: livepkgr m3u8 and f4m out of sync
SE_0208 Feb 18, 2013 6:01 AM (in response to Michael Kennedy (12345))Do agree with Micheal on his second point.
6. Re: livepkgr m3u8 and f4m out of sync
CarphuntinGod Feb 18, 2013 7:10 AM (in response to SE_0208)Thanks everyone for the info. That's the sort of stuff I need to know to proceed.
Our radio station does some event stuff that people will listen to online. The radio station will tell them that the inet stream is not "live" per se... but in the past, with the FMS 3.5 server... it wasn't very far out of time. I'm just trying to keep the new streams we will put up as close to in time as possible.
