3 Replies Latest reply on Feb 11, 2013 5:48 PM by conroy
    Problems Stroking Path with the pencil cs6
    JovenPaul
      I´ve been making pixel art for a while now and recently I upgraded to cs6.
      all was fine till I tried to stroke a circular path with the pencil tool.
      The Circles it makes are completely uneven. I cant figure out a way to fix this. Help please.
      These are the paths i traced in different sizes
      this is the stroked path with a 1 x 1 pixel pencil
      as you can see the the bottom and right part of the circles is different from the top left. it is more noticeable on smaller circles.
      it also happens with bigger stroke sizes.
      this diddn´t happen in cs5.
      I would appreciate any input.
        • 1. Re: Problems Stroking Path with the pencil cs6
          DrStrik9 Level 4
          I don't know what happened in this regard between CS5 and CS6. But your examples appear to be the natural result of working very low-resolution with no anti-aliasing. There are only so many places Photohop can place a non-anti-aliased pixel, given the very few choices it has in such a low resolution document.
          As an experiment, try Edit>Stroke, with a single pixel on the path center (or its selection), and see if you like what it does. The only real difference will be that your stroke will be anti-aliased.
          Alternatively, try increasing your document resolution, if your project allows.
          • 2. Re: Problems Stroking Path with the pencil cs6
            conroy Level 5
            If a path is in precisely the same location in CS5 and CS6 then strokes made with the Pencil will be almost (or possibly actually) identical in both versions. However, CS6 has an added preference to restrict the positioning of paths with respect to the pixel grid and I think that the positioning of your paths is not as you intended. You'd have got reasonably symmetrical Pencil-stroked circles if the N, E, S and W points of the circular paths lay mid-pixel. These points in your example are lying on pixel boundaries, hence the asymmetrical strokes.
            To get CS5's free positioning of paths in CS6, disable Preferences > General > Snap Vector Tools and Transforms to Pixel Grid. Then it'll be possible to get in CS6 the result that you got in CS5.
            • 3. Re: Problems Stroking Path with the pencil cs6
              conroy Level 5
              This is quite symmetrical. See how the path is mid-pixel at N, E, S, W.
