1. Re: making this shape, very simple yet i don't know how
Noel Carboni Feb 11, 2013 7:01 PM (in response to ggameon)Have you tried drawing one of the tabs with the Pen Tool?
A helpful technique is to open the image with the shape you want to trace, then draw the path using the image as a guide. Then make a new shape layer out of the path, and adjust the points for the best possible match, and finally delete the image from underneath.
There are some helpful shortcuts, such as Photoshop keeping the next point on the same horizontal or vertical alignment if you hold down the Shift key while moving to the next point.
The Pen Tool and path operation in general are well worth getting to know well.
-Noel
2. Re: making this shape, very simple yet i don't know how
Noel Carboni Feb 11, 2013 7:03 PM (in response to Noel Carboni)FYI, here's the PSD if you'd like to examine the path more closely: http://Noel.ProDigitalSoftware.com/temp/Tab.psd
-Noel
3. Re: making this shape, very simple yet i don't know how
ggameon Feb 14, 2013 2:16 PM (in response to Noel Carboni)Huge thanks Noel
I'm now working on learning to use the pen tool properly. It will work out soon
Thanks again
