2 Replies Latest reply on Feb 12, 2013 1:32 PM by wdg1932
    Need zero filled text field to export leading zeros
    wdg1932
      I am working on a form that needs to combine several fields one of which has leading zeros.
      Using information mostly from this site I have put the following together.  It works exactly as I want Except the field MemberNumber field does not bring over any leading zeros.  I thought the ValueasString would do that for me but does not.
      // Custom calculation script
      (function () {
      // Get the field values, as strings
      var sdc1 = getField("ABA").valueAsString;
      var sdc2 = getField("MemberNumber").valueAsString;
      var sdc3 = getField("CheckNo1").valueAsString;
      // Set this field value by concatenating the field values
      event.value = (sdc1 + sdc2 + "C" + "  " + sdc3) ;
      The field MemberNumber uses the following (also from here I think) and works great for that field in filling in the leading zeros.
      // Custom Format script
      (function () {
          // Get the character limit for this field
          var max_chars = event.target.charLimit;
          // Define the pad character to use
          var pad_char = "0";
          // If the field is not blank and there is a character limit, pad value with leading zeroes
          if (event.value && max_chars) {
              event.value = (new Array(max_chars + 1).join(pad_char) + event.value).slice(-max_chars);
      Thanks for any help. Bill
