This content has been marked as final.
Show 3 replies
1. Re: What does "Purge" do?
Rick Gerard Feb 12, 2013 1:51 PM (in response to Needa_Pickle)Purge frees up memory, it does not clear the disk cache. Your ram previews and audio previews are stored in memory. Basically everything in the timline with a green line over the frames is stored in memory. If you're also getting a blue line then you have disk cache turned on.
If you have AE configured to use Disk Cache in the preferences then you should go in anc clean in out on a regular basis.
2. Re: What does "Purge" do?
Tim Kurkoski Feb 12, 2013 2:14 PM (in response to Rick Gerard)You can clean AE's disk cache by going to Preferences > Media and Disk Cache, then click the Empty Disk Cache button.
