5 Replies Latest reply on Feb 13, 2013 6:47 AM by DBLjan
    parent page or spread?
    DBLjan Level 3
      I'm fiddeling around with this one and i beg for some help:
      set currSelection to object reference of item 1 of selection --Script will only be used when text is marked
      set parentTextFrame to item 1 of (parent text frames of currSelection)
      set parentPage to parent page of parentTextFrame --Get the page
      set theLine to make graphic line at parentPage with properties {geometric bounds:{A, B, C, D}, stroke color:"Linecolor", stroke weight:1}
      This works fine. But only if the textbox is on a page. But often I prepare those textboxes left/right offpage on the spread for late usage – then the script doesn' work, because parent page returns nothing, and i cant just exchange that with parent spread. I dont't know how to draw the line there. Further I don't know, if a spread belongs to/has a page number: My document has more than one pages, and the line should be drawed over that marked text on the spread.
      Can someone help me out?
        • 1. Re: parent page or spread?
          @DBLjan – the parent of the text frame is the Spread object (at least in JavaScript/ExtendScript, but should also work with AppleScript). I'm not into AppleScript, so I can give no further hints when it comes to exact syntax…
          Hope, that helps!
          Uwe
          • 2. Re: parent page or spread?
            Peter Kahrel Adobe Community Professional & MVP
            Use just 'parent', which returns the spread:
            set theLine to make graphic line at parent with properties {geometric bounds:{A, B, C, D}, stroke color:"Linecolor", stroke weight:1}
            My first ever Applescript! The JavaScript version of this works fine.
            Peter
            • 3. Re: parent page or spread?
              DBLjan Level 3
              Hm. I tried that with make … at parent and got some strange behaviour, depending on zoom, view-place…i guess. I cant describe it, but that pony doesnt do the trick.
              I worked around it a bit like this, to keep the script working
              if class of parentPage as string = "page" then
                                  else
                                      set parentPage to parent of parentTextFrame
                                  end if
              Also, when the box is on the right side of the right page, the line's x is put at the left page:
              I dont really understand, what my textbox's "parent" is nor why i cant make graphic line over where my box actually is.
              • 4. Re: parent page or spread?
                @DBLjan – Hm, maybe you are running in a trap with the coordinate system, that is set to single pages.
                You have to define your coordinate system to Spread beforehand, I think…
                Uwe
                • 5. Re: parent page or spread?
                  DBLjan Level 3
                  I made some more adjustments, and this seems to work. I dont know exactly why, but: mates, i think we got this.
                  I googled some code which helped someone to create cropmarks on documents with different zero points and came to this:
                  set rulerOrigin to ruler origin of view preferences
                    if rulerOrigin is not spread origin then set ruler origin of view preferences to spread origin --(spread origin/page origin/spine origin)
                  set rulerZeroPoint to zero point
                    if rulerZeroPoint is not {0, 0} then set zero point to {0, 0}
                  --> Here I nested my code, the fetching of the coordinates (like set Y1 to baseline of first character in selection) and the drawing of the line.
                  --> And set it back:
                  set zero point to rulerZeroPoint
                  set ruler origin of view preferences to rulerOrigin
