1 Reply Latest reply on Nov 25, 2007 8:08 PM by oakmad
    Installing Flex Builder 2 problem
    Steve Pruitt Level 1
      Has anyone had problems in the FB2 installer getting past identifying the Eclipse folder? I enter what should be a valid folder. It contains Eclipse 3.3. The folder is the top level folder containing both the .exe and configuration folder.
      But, I get an error stating I must choose a folder with 3.1 or greater and containing the standard configuration folder. The folder I enter meets all criteria, yet it is rejected.
      I use the Chooser... button to select the following folder.
      C:\Program Files\eclipse
        • 1. Re: Installing Flex Builder 2 problem
          oakmad
          Yes I tried that to work around my problem Flex Builder crashing. My Eclipse 3.3 install works fine, Flex Builder will not even start. The plug-in installer would not get past that same screen, I downloaded 3.2 and it installed fine, I assume it checks the version and 3.3 is not supported.
