0 Replies Latest reply on Feb 19, 2013 2:22 PM by janelle_f
    Selections in PS Touch for phone
    janelle_f Adobe Employee
      Making a selection
      Select the Rectangular Marquee tool. Drag a rectangle onto the image. The moving border indicates a selection.
      When moving a selection, you are moving the selection area, not selected pixels. To move the pixels in a selected area, use the Transform tool.
      Deselecting
      To deselect the area, tap once outside the selection or choose Edit > Deselect.
      Clearing a selection
      To remove the image inside of a selection, tap Edit > Clear.
      Adding to or removing from a selection
      Create a selection. Tap Mode. Tap Remove from Selection to select and remove areas from the current selection. Tap Add to Selection to select and add areas to the current selection. Tap the button again to change modes.
      Feathering a selection
      To create a soft-edged selection, you will "feather" it. Create a selection, then tap Edit > Feather.
      In the Feather dialog, move the slider left or right to affect the softness of the selection edge. Tap the check to finish.
