1 Reply Latest reply on Nov 21, 2007 9:13 AM by RoboColum(n)
    Import Links from JavaDocs HTML Files
    comm-guru
      In my Win XP environment on Robo7, I have broken links when I import HTML files from JavaDocs. How can I avoid these broken links?
        • 1. Re: Import Links from JavaDocs HTML Files
          RoboColum(n) Level 5
          Hi comm-guru and welcome to the RH community.
          I think your problem here is that in RH the link uses the project directpry as it's base. Therefore linking to topica.htm in the project when it is in folder a the link syntax is foldera\topica.htm. With your imported HTM files, are the file paths different? If so, you will have to change them to reference the rules above. Either that or just mend the links.
          Oh and one more thing. Please do not cross post across more than one forum. Those likely to respond monitor all of them so we are bound to see your post. Also its against the forums rules!
