1. Re: creating a poster in the contact print module
web-weaver Feb 13, 2013 2:06 PM (in response to billsumner)In the Print Module, right side top, in the <Layout Style> panel select <Custom Package>.
Then, on the left side under <Lightroom Templates> select any of the templates called "Custom ....".
Now on the right side in the <Cells> panel click on <Clear layout>. This will remove all cells.
Then in the same panel under <Add to Package> click on one of the small triangles and select <Edit>. Select a cell size you like. The newly created cell size will appear on the button, click it repeatedly to fill the page with cells.
Note: the photo will fill the cell completely only if you have cropped it to the same side ratio that the selected cell has. For instance, if you select square cells, you have to crop your images square, only then will it fill the cell.
Then, on the right side, higher up, in the <Image Setting> panel check the box <Inner Stroke>, choose a width for the stroke and select a color by clicking on the small square (by default it's white, I believe). This will give you the lines around the images.
