2 Replies Latest reply on Feb 14, 2013 9:57 AM by TimJaramillo
    Using an array to show/hide multiple elements?
    Ashish Gatne Level 1
      I have two elements that need to be hidden:
      "mov-imp"
      "mov-pim"
      Currently, I am doing this:
      var arr = ["mov-imp", "mov-pim"];
      // This is the onclick function
      sym.$.each(arr, function(){
                          $(this).hide();
      What's the best way to show/hide multiple elements/symbols in AE?
      Thanks!
        • 1. Re: Using an array to show/hide multiple elements?
          I would like to add, I'd like to use this in the following syntax:
          var mySymbolObject = sym.getSymbol("<my aray name goes here>").play("animation");
          • 2. Re: Using an array to show/hide multiple elements?
            TimJaramillo Level 4
            Hi Ashish, here is how you can hide all symbols in an array on button click. I'm not sure what you're asking in your second post, if you can clarify that.
            Example:
            www.timjaramillo.com/code/edge/arrays_hide_objects
            Source:
            www.timjaramillo.com/code/edge/_source/arrays_hide_objects.zip
            Code on button.click event:
            // if this button stays at root, you can just call sym.hideObjects();
            // this is in case you nest your button inside other symbols
            sym.getComposition().getStage().hideObjects();
            Code on Stage.compositionReady:
            var arr = ["obj1", "obj2"];
            sym.hideObjects = function(){
                      $.each(arr, function(index, value) {
                                sym.$(value).hide();
