I am getting aggravated. Everytime I go to a site, I am asked to download the latest version of Adobe Flash Player, which I have done over and over and over and over again. Why do I keep getting this message when I already have it installed?
Hy! I have the same problem by more time... any solutions? Thank you
What operating systems and browsers are you both using? Is this something that happens every time? Are you successfully installing Flash Player when you run through the installer?
Chris
Dear Chirs thank you for attention. I hace a pc with Windows 7 64 bit Ultimate and I use the Internet exploer 9. This problem happens every time I open the browser and the installing flash says that is successfully installed! After work I try to uninstall and reinstall IE9 and then renistall Flash player... so i write to you as soon as for the news! Best regards
Luca
Hy Pat! Like i write I tried to uninstall and reinstall Internet Explore 9 and then install the last version of Flash Playee but the problem is the same. After few time that I open the browser IE9 come out the pop up for upgrade Flash player to version 11.6. I made this but another few time come out again and again... If I link to "Find Version" the web site says that the flash player is running and my version is 11.6.602.168. If I go to control panel and I find adobe flash 32 bit it says the same version also plug in. Can you help me?
Sorry, I do not understand - what additional help do you need?
Hy Pat excuse for my english.. Like I wrote I installed Flash Player vesrion 11.6.602.168 in my windows 7 64 bit and browser IE9. But often after I open the browser and start the web navigation comse out the pop up of upagrade Flash Player but i still have the last version. So i made the upgrade. But a few time after the pop up comes out again... I try uninstall and reinstall, clenaing cache and registry but this problem contiune... For notice the problem of the continuosly upgrade happened when works Internet Explorer 9 while (for trial I installed Mozilla Web browser) with firefox the pop up of upgrade don't comes out and works fine. Any suggestion for ending this problem?? I hope to explain the mistake correctly. As soon as Luca
I get the message that it is running, but it isn't. I am asked to reinstall it every time that I go to a site that requires it.
Help, I have the same problem. I'm using the most recent version of Flashplayer, with Firefox, on Windows 7 with 64 bit. It pops up, I hit 'no' (to installing it), and then things proceed. (I have downloaded and installed, and then uninstalled flashplaye several times. I get the same results each time.
Can someone tell me if this is harmful (or just makes me crazy)? Or is there something I can do to resolve it?
