3 Replies Latest reply on Feb 19, 2013 10:55 AM by Steve Bishop
    Display dynamic content
    Orpinder Level 1
      Hi
      Hoping anyone can help I am currently using Livecycle Designer ES2.
      The current form has a subform which contains drop downs, notes section and price fields. These three fields are repeated 4 times each has different selections in the drop downs, different typed notes and different prices.
      Example
      drop down 1: unit a, unit b, unit c
      note 1: user typed
      price: 23.99
      drop down 2: unit a, unit b, unit c
      note 2: user typed
      price: 45.99
      and so on
      What is currently being produced is a invoice page showing all four sections regardless if there is any data in the fields which is leaving blank spaces on the invoice sheet.
      What i would like to happen is that if drop down 1 and 4 and filled in then on the invoice page it only shows those 2 one after the other with out having gaps where the other should be if filled in.
      Any help or examples would be appreciated
      Many Thanks
        • 1. Re: Display dynamic content
          Steve Bishop Level 2
          if [whatever your condition] subForm2.presence="hidden";
          if [whatever your condition] subForm3.presence="hidden";
          • 2. Re: Display dynamic content
            Orpinder Level 1
            Thanks for the reply.
            The main issue is not to do with having the forms hidden/visable
            I will try to explain better.
            On the last page i have 4 subforms which are hidden.
            Depending on the conidtions from the drop down list on the form anyone of the 4 subforms can become visble while the others remain hidden.
            The problem starts when subform 2 and 4 are visble and subform 1 and 3 are hidden. There are empty gaps where subform 1 and 3 are. But the end result should be subform 2 and 4 next to each other so there are no gaps while subform 1 and 3 remain hidden.
            Its a case of moving the subforms so that the document flows without gaps
            Hope that explains it more
            Thanks.
            • 3. Re: Display dynamic content
              Is the parent of subForm1-subForm4 flowed or positioned?
