2 Replies Latest reply on Feb 15, 2013 3:48 AM by Panasaki
    Access to Apache Felix Configuration from a Servlet or Sling Service
    Panasaki Level 1
      Good afternoun,
      I have created a Sling Service with different Properties configured from Apache Sling.
      I would like to know if there is a way to access to this properties from a Servlet or another Sling Service.
      This I am trying to do, to recover the path where the first Service created is stored information and it is configurated from Apache Felix Configuration.
      I am looking information about that and I cannot find it.
      Thank you for your help in advance.
        • 1. Re: Access to Apache Felix Configuration from a Servlet or Sling Service
          konradhh
          Your Service:
               * A configuration item
               * @scr.property label="Something to configure" value="your default value"
               * description="some description"
              private static final String MY_CONFIGURED_VALUE = "my.configured.value";
          private Dictionary<?, ?> properties;
          private String myConfiguredValue;
          public void activate(ComponentContext context) {
               properties = context.getProperties();
               //get your configured value
               myConfiguredValue = (String) this.properties.get(MY_CONFIGURED_VALUE);
          Create some public getter:
          public String getMyConfiguredValue(){
               return myConfiguredValue;
          And in the other Service you can refrence to your service:
               * @scr.reference
              private YourOtherService yourOtherService;
          And here you can use this service and all public methods:
          yourOtherService.getMyConfiguredValue();
          Should run^^ give it a try.
          • 2. Re: Access to Apache Felix Configuration from a Servlet or Sling Service
            Panasaki Level 1
            I have achieved the solution in that way:
            Creating the Reference in the Sling Component, in my case in the Servlet and in a Job Service different of the Service that define the configuration attributes
            @Reference
            private ConfigurationAdmin configurationAdmin;
            And recovering in that way:
            final String configurationToRetrieve = (String)this.configurationAdmin.getConfiguration(classOfTheService.getCanonicalName()).ge tProperties().get("AttributeName");
            Or in the own Service that define the configuration attributes in the Activate Method to check if is correct:
            @Activate
            protected void activate(final ComponentContext context) {
                               final String configurationToRetrieve = (String)context.getProperties().get("AttributeName");
            Thank you for your help, and I hope our contributions will help to someone.
