2 Replies Latest reply on Feb 15, 2013 4:40 AM by yuskales
    Print Booklet Problem
    yuskales
      Indesign print booklet is not working correctly. I only get the left side of the page spread. It worked correctly 2 days ago on the same document. I am printing the file with the postscript printer and using Distiller to make a PDF to send to my print company. Working with a Mac OS10.8.2 and Indesign CS5. Any ideas on how to correct this problem would be appreciated.
        • 1. Re: Print Booklet Problem
          BobLevine MVP & Adobe Community Professional
          I'll give you the same advice I give everyone else in this situation.
          Find another printer. A printer asking you to do the imposition is like
          a mechanic asking you to pick up oil and filter before dropping off you car.
          Bob
          • 2. Re: Print Booklet Problem
            yuskales Level 1
            Through trial and error I got it to work again. With Print Booklet selected: Open (Print Settings) set Print Preset to (Custom), Printer to (PostScript File), PPD to (Adobe PDF 9.0). Next go to Setup add the full size of your spread, Marks and Bleed, Output etc. This worked for me.
