There is a problem with displaying more than 10 Search results per page in IE9 webhelp. I have updated whform.js to display 99 results per page as follows:
var gnMaxRslt = 99;
After updating whform.js it shows 99 in the textbox, but displays only 10 in the search results below.
Can anyone suggest a solution?
In RH10 you need to amend the whfhost.js file as well as the whform.js file. Go down toward the bottom of the whfhost.js file and change the following statement:
var nMaxResult = <number required>
e.g.
var nMaxResult=99
Remember that every time you build the project the RH default files will be added. So I find it is best to keep a copy of the amended files and copy them over after building the project and before publishing.
Hope this helps.
Chris
e.g.
var nMaxResult=99
Hope this helps.
Chris
Many thanks for that IR-PROGNOSIS.
I changed the statement in the whfhost.js located in C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML\WebHelp5Ext\template_stock\whfhost.js. As it's in the RH stock templates it only needs to be updated once.
