9 Replies Latest reply on Feb 14, 2013 3:33 PM by resdesign
    Controlling Classes
    JonathanMarino
      Hello Edgers!
      I am wondering how I could control multiple symbols using classes.
      So lets say I have 10 symbols on the Stage - each symbol has a class of 'box'
      Using this:
      sym.getSymbol('.box').play('lower');
      only the first box will animate, not the other 9.
      As always, thank you in advance for your time and help!
      - JM
        • 1. Re: Controlling Classes
          resdesign Adobe Community Professional & MVP
          Yes you can. You can assign a class to your elements here:
          Not sure about your code though. What are you trying to do?
          • 2. Re: Controlling Classes
            JonathanMarino Level 1
            Thanks resdesign.
            Yes, I have already assigned my class to all of the elements.
            Now how to access them w/ the edge API?
            sym.getSymbol('.box').play();
            only works on the first div - all others assigned with the same class do not animate.
            • 3. Re: Controlling Classes
              The API says:
              Accessing imported HTML content through actions can be done by using sym.$("#myId"); to target the ID or class of your element. You can also use this method to target DOM elements which live outside of the Edge Animate composition. For example, sym.$("footer");
              • 4. Re: Controlling Classes
                Thanks resdesign.
                I got a bit frustrated trying to find the proper syntax and couldn't.
                So I just wrote a work-around
                // populate array of objects with class 'box'
                var box = [];
                jQuery(".box").each(function()
                          box[box.length]=this;
                //begin animation
                animate();
                var index=0; //represents current index in box array
                function animate()
                          setTimeout(function()
                                    if(box[index]==null) //if end of array is reached, return from function
                                              return;
                                    sym.getSymbol(box[index]).playReverse();
                                    ++index;
                                    animate(); //this recursive call repeats itself on the next index in the array
                          },10);
                Hope this helps anybody else out there.
                I'll be posting the finished project soon.
                • 5. Re: Controlling Classes
                  Example:
                  var btn1 = sym.$('btn1');
                  btn1.click(function(){
                            //sym.$("myBox3").css('background', 'red');
                            sym.$(".box").css('background', 'red');
                  • 6. Re: Controlling Classes
                    We posted about the same time. Hope the sample above helps.
                    All you need to use the class is:
                    sym.$(".className")
                    • 7. Re: Controlling Classes
                      Thanks so much for your help.
                      I tried that, but it seems to not be able to call the play or playReverse actions.
                      This is triggered on a mouseover event.
                      sym.getSymbol('box1').play('label');
                      I would like to populate numerous symbols - box1, box2, box3, box4 - all with the same class 'box'
                      and have them all play on one mouse event
                      sym.$('.box').play('label');
                      does not seem to work.
                      • 8. Re: Controlling Classes
                        I have to go but I will try to give you an answer by tomorrow unless someone beats me to it.
                        • 9. Re: Controlling Classes
                          OK. I have a question, are you creating the symbols or are they already on the stage?
                          Well so far, I am like you. I can apply css properties to a bunch of elements having the same class but I cannot get them to play.
