4 Replies Latest reply on Feb 20, 2013 4:41 AM by Jennifer Hearing
    Call in different .txt file name, FindChangeByList
    Jennifer Hearing
      On my home computer, I have been using the script FindChangeByList.jsx that Adobe provides with InDesign. It calls in a .txt file called "myFindChangeByList." (from a folder called "FindChangeSupport") I saved a copy in the same folder and added my own Find/Change items for a specific project. When you run the script, it sees there are two .txt files in the folder and asks you which of the two you want to run. I choose the 2nd, and it runs great.
      However,  I am trying to use the file at work. When I try adding the second .txt file to the FindChangeSupport folder, I need admin rights. I would have to call IT and get permission each time I wanted to change the file or add another .txt file.
      I did try naming all references to the .txt file to the name of my second file, but that did not work.
      I don't know anything about scripting, so I was wondering:
      Is there a way in the script (jsx) file to call in my 2nd .txt file no matter where I save it?
      Following is the beginning of the .jsx script -- the file is listed/called several times throughout. I'm assuming I need to change every reference to it?
      main();
      function main(){
          var myObject;
          //Make certain that user interaction (display of dialogs, etc.) is turned on.
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
          if(app.documents.length > 0){
              if(app.selection.length > 0){
                  switch(app.selection[0].constructor.name){
                      case "InsertionPoint":
                      case "Character":
                      case "Word":
                      case "TextStyleRange":
                      case "Line":
                      case "Paragraph":
                      case "TextColumn":
                      case "Text":
                      case "Cell":
                      case "Column":
                      case "Row":
                      case "Table":
                          myDisplayDialog();
                          break;
                      default:
                          //Something was selected, but it wasn't a text object, so search the document.
                         myFindChangeByList(app.documents.item(0));
              else{
                  //Nothing was selected, so simply search the document.
