2 Replies Latest reply on Feb 16, 2013 5:36 AM by ♥Schrene
    ♥How To Sync Content With Video♥
    ♥Schrene Level 4
      Ok so it took a while but I finally got it figured out...
      Yay!!! I can quit pulling out my hair!!!
      You can sync text and animations.... or pretty much anything you can do in Edge... with your video here is my sample:
      I kept the timer visible so you could see.... watch about every 15 seconds the text changes...
      and there is an animation that is activated around 75 seconds
        • 1. Re: ♥How To Sync Content With Video♥
          joel_pau Level 5
          Here is one demo using your text and the edge tool (update panel): https://www.box.com/s/8oc5sbrudnp1o6sclc0j
          You can put your video events (pause, play) within the update panel. Video and subtitles can run in parallel.
          But i tested your link using Safari.
          First load: the console returns an edge error but video and subtitles run in parallel.
          Reload: console returns no errors. Video stops frequently but video and subtitles run in parallel.
          So preload=none, is it a good choice?
          • 2. Re: ♥How To Sync Content With Video♥
            ♥Schrene Level 4
            Oh the joys of browsers not all being on the same page
            I was so excited that I finally found a "solution" that worked so I did not test code on any browser but FF...
            I tested my project in Opera and it's not syncing with text at all????
            I re-uploaded my files and changed the video to preload="metadata"  I'll see if that makes any difference???
            I am wondering if my custom controls might be part of the problem as well??
            I guess it's back to the drawing board....
            As Thomas Edison once said... "I have not failed. I've just found 10,000 ways that won't work. "
            I wasn't aware the update panel existed..... thanks for pointing that out..
            I see how you set up the text to change at specific time.....
            but I don't see how you could put the pause and play button in there so that it would pause and play text as well???
