1 Reply Latest reply on Feb 15, 2013 8:39 PM by robbie_the_voice
    After Effects Rendering error
    richardneubs
      I am trying to render a menu in After Effects and I recieve an error message that reads, After Effects error: REndering error while writing to file "F:\Sean Folder\menu exports-Sean \Main-Menu-With- Intro-HD.mov." Unable to open file. 1610153459
         After Effects CS6 with 11.2 update.
         Windows 7 pro
         Source footage is H.264
         Intel i7-2600 CPU @ 3.40
         16GB Ram
         2 Drives-SSD 160GB ATA & WDC 1TB ATA
      I am using a precomposed menu from PRECOMPOSED.com
        • 1. Re: After Effects Rendering error
          robbie_the_voice
          Hello richardneubs,
          i had a similar problem in Premiere and that over many weeks - no one could help - even not the support.
          i found the problem in a forum: the path which i wanted to save the file or the file-name was too long.
          Maybe this is also your problem - try it, may it´s the solution.
          i´ve seen that in your filename is a space: after With- Intro-HD.mov. Maybe that can be the problem.
          Hope for you it works.
          best regards
          robbie
