5 Replies Latest reply on Feb 16, 2013 3:12 PM by Gordon James McDowell
    Sick of "Rendering Required Files" to Play. Want 1x scrub.
    Gordon James McDowell Level 1
      Multi-cam project. Very large.
      I can get some work done when I focus on a single sequence, and keep working at it.
      But bouncing between sequences results in "Rendering Required Files" and multi-hour delays to be able to hit play.
      Scrubbing works well enough... audio skips a bit but I can easily make out what is being said.
      How can I treat scrubbing as Play? A 1x scrub button? Can a macro be set up if it doesn't already exist?
      I hit spacebar when walking away from computer, and hopefully enjoy pre-rendered audio next work session. But I need a way to work without waiting for an audio render to complete. I move between sequences all the time, and currently am not seeing a productive workflow.
      Could someone explain how I can use scrub in a more user-friendly fashion, without it being so dependent on my current zoom level?
      Thanks, -g
        • 1. Re: Sick of "Rendering Required Files" to Play. Want 1x scrub.
          Jim_Simon Level 9
          Here you go.
          https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
          • 2. Re: Sick of "Rendering Required Files" to Play. Want 1x scrub.
            I've already submitted one (Jan 18 never heard back). I was hoping there was a work-around someone knew about.
            Here's my request copy/paste.
            Title:
            Immediate ability to edit multi-camera scene without need to pre-process audio.
            How:
            To play a scene that I'm working on, often it is necessary to pre-render audio. If the scene consists of multi-camera & multi-audio source with many cameras, this can take hours (on IMHO decent hardware).
            But, if I simply want to scrub the timeline, Premiere is capable of emitting audio indicating how the timeline sounds at that moment.
            I need some IMMEDIATE ability between the two... it need not sound any better than scrubbing... maybe the audio drops out or just doesn't sound quite right. But I need the ability to scrub/play at 1x speed without waiting hours for pre-render of audio.
            Maybe pre-render can be temporarily disabled. Maybe it is a new type of "play". Maybe it is a scrub locked to 1x speed.
            Why:
            My project consists of ~50 lectures. Each lecture is multi-cam coverage with additional audio channels. To edit any individual lecture this is (barely) passable, so long as I'm not flipping between lectures which often requires a re-render of the pre-rendered audio.
            But all these lectures are now to be used in a single timeline. I'd like to copy moments from individual lectures, but I can't review any edited lectures without re-rendering that audio. Even just to identify a snipped of audio... scrubbing is to hard to control speed to make the audio intelligible. Play almost always triggers audio pre-render taking ~1h.
            So to skip thru various lectures looking for key moments is impractical.
            As a work-around I'm using rendered MP4 and importing that, just so I can brainstorm final project easier. But I should really be able to easily pull from my edited lecture timelines, and so have access to multiple audio channels and camera angles right now. I only import rendered MP4 because I can't wait an hour just to identify and copy a 5s moment of audio.
            • 3. Re: Sick of "Rendering Required Files" to Play. Want 1x scrub.
              the_wine_snob Level 9
              Sometimes one does hear back, but usually not, unless more details or clarifications are needed. Often, good Feature Requests just show up in an update or an upgrade. I have had a few of mine make it into the program, but have never had any contact. The requests are read, evaluated and then prioritized (number of requests by different users go a long way here), and then handed over to a design team if they "make the cut."  In a very few instances (very few), an Adobe staffer will comment in a thread and at least tell us if some work is being done. They are necessarily tight-lipped on this work, but it IS nice to know that a request has been escalated to the team.
              • 4. Re: Sick of "Rendering Required Files" to Play. Want 1x scrub.
                wfmc staffer Level 2
                I've seen people complain about this before and I wonder how I always manage to avoid it. One thing that confuses me is why would somebody need to repeatedly go back to edit a source sequence in a multicam project.
                When I have a multicam edit, I have a sequence that is used to sync. I may Color Correct, Scale Adjust, Re-sync additional footage, and make audio adjustments. But after that the syncing sequence is done and the actual multi-cam editing is ready to begin. I would only go back to the Sync sequence if I had made a mistake somewhere.
                As a time saving measure, I always copy all of the viable audio tracks from the sync sequence and paste it, synced into the multicam sequence. That way I always have the raw audio to work with.
                • 5. Re: Sick of "Rendering Required Files" to Play. Want 1x scrub.
                  Thanks for the insight.
                  I do see a pattern... someone like myself mentions a problem, and it could be either a feature request or a desperate plea for help, depending on the existence of a work around.
                  Feature requests seem to be private, so there's no opportunity for other users to point out what might be an obvious work around.
                  I can't imagine any feature I wouldn't also want to bounce off the forum to see if I'm missing an obvious work around, or if the feature exists and I'm overlooking it.
